kearney(at)shaw.ca Guest
Posted: Sat Oct 07, 2006 2:07 pm Post subject: Compressor Info |
Hi
A couple of weeks ago I queried the list for compressor recommendations. Always one to take good advice, I just purchased a Husky VT6315 from the Home Depot Aviation Department based on the list recommendations.
After run in of the motor I decided to see how loud it really was. Using my Radio Shack sound meter, it clocked in at 89-90db from about 3 feet away. This seems to be consistent with what CH says about the unit and is lower than the DB ratings on other units. Although it doesn’t seem that loud, I may build an insulated box for the unit anyway. If I do, I’ll post the before / after sound levels.
Cheers
Les
RV10 Awaiting empennage kit
VHMUM(at)bigpond.com Guest
Posted: Sat Oct 07, 2006 2:21 pm Post subject: Compressor Info |
MAAATE dont get bogged down with this stuff its just a compressor move on Build that plane!!!
Kind regards Chris
Rick S.
Posted: Sat Oct 07, 2006 2:22 pm Post subject: Compressor Info |
lol....I said the same thing then the emp kit showed up...sound box never got built.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
LarryRosen
Posted: Sat Oct 07, 2006 7:14 pm Post subject: Compressor Info |
The only time the compressor noise will be an issue is when you are
using a die grinder. So, get your self some ear plugs. For all other
operations it will only kick on a few times a day.
Larry
#356
Rick S.
40185
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
wv4i(at)bellsouth.net Guest
Posted: Sun Oct 08, 2006 3:37 am Post subject: Compressor Info |
I must have final drilled several hundred holes on the HS assy skin
yesterday, and my compressor ran constantly, using a Husky air drill.
It's a Harbor Freight special, 21 gal, rated 5cfm (at) 90psi supposedly. It
also takes a dedicated 120vac 15A line to run (share garage door opener
120vac svc), and/but I wanted to avoid 240vac requirement. It's loud,
and I wear ear protection (eye too of course). This is my second HF
compressor as the first one literally blew a head gasket. They use cheap
head bolts that apparently stretch (could see the lock washer split on
1st one). No recommendations here, just food for thought. You will use
your compressor a LOT during the build process. If I had extra 240vac
svc avail without calling an electrician, or dryer outlet was a little
closer, ideally I would have a well built 240vac compressor capable of
9cfm(at)90psi (see tool air requirements) and not (have) wasted time and
hearing on a lower end compressor. May still upgrade.
Link McGarity
#40622 HS assy
jjessen
Posted: Sun Oct 08, 2006 7:27 am Post subject: Compressor Info |
Les, build the sound box, the storage cabinets, the shelves, put in a nice run of air compressor hose and water traps, paint the floor, etc, etc, because onece that puppy shows up, forget it. You'll be lucky you take time to recognize your wife and kids!
John J
#40328 (riveting the tailcone)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Saturday, October 07, 2006 3:02 PM
Subject: Compressor Info
Hi
Cheers
Les
href="http://wiki.matronics.com">http://wiki.matronics.com
MauleDriver(at)nc.rr.com Guest
Posted: Mon Oct 09, 2006 6:01 am Post subject: Compressor Info |
I recently bought the same compressor. Using the drill and rivet gun 2
to 3 hours at a time, it usually does not come on. When it does, it's
once a session. You have to wear ear protection anyway so ....
Bill W - last rivets on HS, initial elevator assembly
Larry
#356
> never got built.
> Rick S.
> 40185
billykay1(at)aol.com Guest
Posted: Mon Oct 09, 2006 7:57 am Post subject: Compressor Info |
Les,
Thanks for your info, would like to know the before and after sound
levels.
Billy K.
emp 574
never got built.
Rick S.
40185
Posted: Mon Oct 09, 2006 1:32 pm Post subject: Compressor Info |
You just may be psychic! Roadway just called to say my tail kit is Edmonton! Then again, my tools are still en route so I just may get to the floor, the compressor box and of course more lights.
Cheers
Les
RV10 Tail kit lost in customs….
