Deems Davis
Posted: Tue Oct 03, 2006 6:13 pm Post subject: Opinion regarding air vents |
For those of you that are flying or for those of you that have spent
some time in one of the transition aircraft. How would you assess the
need/desirability of overhead fresh-air vents? I've read comments that
the standard Van's vents provide an abundance of air, however most of it
is aimed to low (gonad refrigerant). If the Naca Vents were ducted to
provide fresh air to the pilot/copilot face/head/trunk from a little
higher on the instrument panel,would the overhead vents still be worth
having ? I've got the Cabin cover off and now would be the right time
to add something if it's necessary, If it's not that's one modification
I'd be happy to forgo.
Deems Davis # 406
Panel/Finishing
http://deemsrv10.com/
Where it's only 120 degrees for just a few minutes in the am b4 heading
up to really hot. (It's OCT and stilllllllll 100!)
Tim(at)MyRV10.com Guest
Posted: Tue Oct 03, 2006 6:42 pm Post subject: Opinion regarding air vents |
Howdy Deems,
Personally, I still think the vents are one of the biggest design flaws
keeping it from being perfect. Even if you put the vents up higher
on the panel, you may want to redesign things a little. I've now found
when flying in rain that indeed the rain does come in the vents, and
if you close them, a puddle will form and it will bubble water into
the plane. So at minimum, some drains might be a good idea, that drain
to tubes out the floor. But even then you'd be stuck with keeping the
vents closed in the rain. So to me, overhead vents would be a great
thing to have. I used to use my overhead vents nearly year round
in my old plane...I just liked a little fresh air on my face. But
when you're limited to only the 2 big vents up front, it's just
not as easy to make things comfortable. Once some people get flying
with overhead consoles and everything is plug-n-play, I may actually
add one to mine.
Deems Davis # 406
Panel/Finishing
ScooterF15
Posted: Tue Oct 03, 2006 9:16 pm Post subject: Opinion regarding air vents |
In my opinion, the stock vents are quite adequate for cooling. You can point them up toward your face if you need it, or elsewhere if you don't want all that wind blowing on your microphone. For a while I had diverted the passenger vent for avionics cooling... I was able to keep the most finicky passengers happy in 100 deg weather by directing the pilot's vent cross cockpit.
Personally, I would not spend the effort or panel space raising the stock vents higher or installing overhead vents.
Jim
40134 - Flying
Jim "Scooter" McGrew
Graduate Student
Humans and Automation Lab (http://halab.mit.edu)
Department of Aeronautics and Astronautics
Massachusetts Institute of Technology
In a message dated 10/3/2006 10:15:24 P.M. Eastern Daylight Time, deemsdavis(at)cox.net writes:
Quote: | --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>
Deems Davis # 406
Panel/Finishing
dav1111(at)cox.net Guest
Posted: Wed Oct 04, 2006 1:26 am Post subject: Opinion regarding air vents |
I second Jim's Opinion, but like Tim Olson, I may add an overhead console and overhead vents when I install my flightline interior (less seats), due for delivery in January. My wife installed a headliner but decided after Grady O'Neal at GLO Custom Paint did such a wonderful job on the paint that she wanted me to order the Flightline interior.
Russ Daves
N710RV - First Flight 7/28/06
LOE 2006 Bound
AV8ORJWC
Posted: Wed Oct 04, 2006 5:12 am Post subject: Opinion regarding air vents |
Great way to strategize the financial decision-making Russ. Hope my wife does not read this.
I am having VANS delete the NACA and rear PAX ducts from the fuselage skin CNC punch. I am relocating the NACAs farther forward (up against the firewall) and directing them higher where air ducts are normally designed to be located. My gonads will be just fine - thanks. This requires mounting the rudder pedal mounts lower and having the side tubing shortened (the exact distance the mount blocks are lowered). I liked the dark charcoal powder coat effect, so the weld process will be done preparatory to the last color powder coat. The rear Pax will have total control from the empennage mounted NACA with “forward flow” overhead air plenum (Like Mooney, Piper, Beechcraft and Cirrus). Stole the idea from Ed Hayden. Size adequacy was not the issue for me, it was the blatantly poor design placement. However Ed’s team found that a larger overhead orifice reduced the air stream whistle during Max Cool.
Jepp charts can be just too darned important on a hot day (to stay on my lap). Secondly the routing of the ductwork can allow for removal of condensate before it bubbles into the hermetically sealed avionics cockpit – Dehumidifiers anyone?. We are going into our 6 months of 85% humidity from the gentle Pacific Ocean Maritime flow just now.
40600 – Flying in my mind daily
Do not Archive
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Russell Daves
Sent: Wednesday, October 04, 2006 2:26 AM
Subject: Re: Opinion regarding air vents
Russ Daves
LOE 2006 Bound
----- Original Message -----
Sent: Wednesday, October 04, 2006 12:15 AM
Jim
40134 - Flying
Graduate Student
Deems Davis # 406
Panel/Finishing
http://deemsrv10.com/ |
