Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Wed Sep 27, 2006 9:54 am Post subject: Stick Transfer function |
Howdy again-
Thanks to all who offered suggestions for the lighted, engraved rocker switches- now have two sources, Pacific/Gulf Coast and Aerocraft.
Next question. I am investigating how to swap all stick switch functions from L to R (Infinity grip) by some reliable, safe means. About 8 wires minimum (4-way trim, CWS, PTT, gnd). I would prefer a simple switch as opposed to using relays (4PDTx2) but I'm beginning to think there is no source for an 8PDT switch.
Any suggestions or am I barking up the wrong tree and there's a simpler way to do this?
THANKS!
Mark Phillips do not archive
_________________ From The PossumWorks... |
retasker(at)optonline.net Guest
Posted: Wed Sep 27, 2006 11:47 am Post subject: Stick Transfer function |
I don't think you are going to find a toggle with that many poles.
However, assuming that you really want to do this, a rotary switch would
do what you want with no problem. You would almost assuredly have to
solder to it as finding a switch with that many poles with screw
connections is unlikely nowadays.
Try Mouser #690-C4D0806N-A
(http://www.mouser.com/search/refine.aspx?Ntt=690-C4D0806N-A) for example.
Dick Tasker
Fiveonepw(at)aol.com wrote:
| Quote: | Howdy again-
THANKS!
rvbuilder(at)sausen.net Guest
Posted: Wed Sep 27, 2006 12:51 pm Post subject: Stick Transfer function |
As far as trim functions go you can look into something like this:
http://www.f1-rocketboy.com/tcm.html
Michael Sausen
-10 #352 Buldus Interuptus
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Fiveonepw(at)aol.com
Sent: Wednesday, September 27, 2006 12:53 PM
To: aeroelectric-list(at)matronics.com; rv-list(at)matronics.com
Subject: Stick Transfer function
Howdy again-
THANKS!
01234567890123
Bill Schlatterer
Posted: Wed Sep 27, 2006 6:57 pm Post subject: Stick Transfer function |
Mark, have you looked at these. I have them but not yet flying but they appear to work fine. No need to swap, the pilots always overrides the CP and you can shut off the the CP if you like. Also has dual speed and runaway trim control. Only handles 4 trim circuits.
http://www.f1-rocketboy.com/pcm.htm
Bill S
7a Ark
Howdy again-
THANKS!
RobHickman(at)aol.com Guest
Posted: Wed Sep 27, 2006 8:37 pm Post subject: Stick Transfer function |
With the standard Ray Allen servo relays you can connect all the buttons you want to the servo. This is also the case with Van's flap relay deck for the flaps.
I have trim and flaps connected to the front and rear stick in my RV-4 and it has worked for 7 years without any problems.
Why worry about the rear seat person pressing the button also? If they can press the button they can also grab the stick and that is a worse problem. I have flown with my kids since they were 5 years old and it has never been a problem.
The only problem that I have ever had with a rear seat passenger in 500 hours was when a 14 year old girl on a Young Eagles flight accidentally unbuckled and then had a panic fit about it. I finally managed to calm her down enough and reach around and buckle the lap belt.
Rob Hickman
N401RH RV-4
chaztuna(at)adelphia.net Guest
Posted: Fri Sep 29, 2006 4:52 pm Post subject: Stick Transfer function |
Mark,
I wanted to have the same "absolute" control myself. I settled for using a four pole, double throw switch to control the electric trim and a three pole, double throw switch for the flaps. Center position of each switch is OFF, in case of a runaway. PPT can be handled by most intercom systems. I went with the RAC G307 grip, because it's 15 amp rated hat switch eliminates the need for trim servo relays. I've got AutoCAD schematics of both my Flap and Electric trim circuits. I'd be happy to send them to you, if you like.
The switch part numbers are on the CAD drawings. I used the same Carling Technologies switches that B&C, Waytek Wire and others sell. I think I bought them from Mouser.
Charlie Kuss
[quote]snipped
THANKS!
michele.delsol(at)microsi Guest
Posted: Sun Oct 01, 2006 9:48 am Post subject: Stick Transfer function |
With a tandem arrangement, dual control seems to require relays, both for flaps and for trims. I went for the RAC relays on the trims, a relay board from Aircraft Extras for the flaps. The neat part is that it is simple to isolate the rear pilot seat trims and flaps since the use of relays is based on connecting to ground. By isolating the rear pilot switch from ground, rear pilot trims and flap controls become inoperative.
Michele
RV8 Fuselage
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie Kuss
Sent: samedi 30 septembre 2006 02:44
To: rv-list(at)matronics.com
Subject: Re: Stick Transfer function
Mark,
Charlie Kuss
snipped
THANKS!
01234567890123
Posted: Mon Oct 02, 2006 5:01 am Post subject: Stick Transfer function |
Michele,
For MOST stick grips, your statement below is true. However, RAC's newest grips, the G305 and G307 series, have hat switches which are rated at 15 amps. This negates the need for relays, and simplifies wiring. Most other grips use hat switches with a 1 amp rating.
Charlie Kuss
[quote] With a tandem arrangement, dual control seems to require relays, both for flaps and for trims. I went for the RAC relays on the trims, a relay board from Aircraft Extras for the flaps. The neat part is that it is simple to isolate the rear pilot seat trims and flaps since the use of relays is based on connecting to ground. By isolating the rear pilot switch from ground, rear pilot trims and flap controls become inoperative.
Michele
RV8 Fuselage
From: owner-rv-list-server(at)matronics.com [ mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Charlie Kuss
Mark,
Charlie Kuss
snipped
THANKS!
