PIA depicted
naumuk(at)alltel.net
PostPosted: Sat Sep 30, 2006 7:08 pm    Post subject: PIA depicted Reply with quote
All-
Spent the day getting this PIA to the point you see. Remember, this was the EASY skin. About 4 hrs.
Bill Naumuk
HDS Fuselage
Townville, Pa
 Filesize:  43.07 KB
 Viewed:  284 Time(s)
cscsail(at)gmavt.net
PostPosted: Sun Oct 01, 2006 3:28 am    Post subject: PIA depicted Reply with quote
Bill,
Looks great, but I noticed you are using what appears to be a light duty polisher for car waxing. I use a Porter Cable 6" Random Orbit Polisher with a speed control and a foam compounding head for the initial work and then use a cloth pad for final polishing. There are other tools that will do a great job as well, but I didn't have the patience to use a car polisher that looked similar to yours.
Gordon
rstone4(at)hot.rr.com
PostPosted: Sun Oct 01, 2006 4:13 am    Post subject: PIA depicted Reply with quote
Hay Bill,
If you make the entire aircraft shine like that it's going to be like flying a mirror. A shine like that with a little bright color trim would look great.
Bob Stone, Harker Heights, Tx
ZodiacXL
PostPosted: Sun Oct 01, 2006 7:59 am    Post subject: PIA depicted Reply with quote
Gordon and all-
My first response got zapped out by Norton- seems someone wants to change my home page. Big deal- they can have it.
I have two auto polishers, a 6" and a 9". I thought the 6" was a straight up rotary, but it turns out it's an orbital, too. Regardless of the brand, I would recommend a straight up rotary for the first pass. Good luck finding one. The bonnets on those that chuck in a drill don't hold tight enough. The bonnet stays still while the backing plate grinds itself to pieces. At this point I have more money in bonnets than the polishers.
Tim Shank turned me on to the Nuvite system, and I have no regrets other than the fact that ACS doesn't carry the heavier F grits. I decided to scrap the fuse side skins and cut new ones using the plastic coated sheet available from Wick's. I'm not comfortable with the fact that I had to remove the worst of the corrosion with 220 grit- I'm sure I weakened the sheet. I figure that I can polish the remaining structure with no coarser than G6. Between not having to pay $40 for an F grit (If I could find it) and the time savings of polishing virgin aluminum, I'm time and money ahead cutting new skins. What the hell, I've got a 50% scratch-built kit as it is!
For those into "Alternative methods" I repeat my observations. Mother's is the grit equivalent of G6, and Dupont Polishing Compound is the equivalent of C. Nuvite S may well be in a category of it's own. I can't say what the corrosion protective qualities of the alternatives are and don't really care since I'm only using the alternatives far upstream of Nuvite C and S.
Good building!
Bill Naumuk
HDS Fuselage
Townville, Pa
PostPosted: Sun Oct 01, 2006 8:13 am    Post subject: PIA depicted Reply with quote
Bob-
Yeah, a mirror with dings, dents, and smileys. I'll just tell people to kick back about 20' and just look at the big picture.
Thank God most of my mistakes are in areas that will be painted!
Bill Naumuk
HDS Fuselage
Townville, Pa
tshank(at)core.com
PostPosted: Sun Oct 08, 2006 6:02 pm    Post subject: PIA depicted Reply with quote
Bill,
Just saw this message, it was caught in my spam filter, anyway you mentioned that AS only carries part of Nuvite's line. I buy mine directly from Nuvite either on-line over the phone or this year up at Osh. You might check with them if the F grades are still available. According to their website http://www.nuvitechemical.com they have F9 and F7 available.
Tim Shankland
Bill Naumuk wrote:
[quote] Gordon and all-
Good building!
Bill Naumuk
HDS Fuselage
Townville, Pa
----- Original Message -----
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
Sent: Sunday, October 01, 2006 7:28 AM
Subject: Re: PIA depicted
Bill,
Looks great, but I noticed you are using what appears to be a light duty polisher for car waxing. I use a Porter Cable 6" Random Orbit Polisherbsp; available via -========================nbsp; Email List nbsp; generous bsp; =================
