n1cxo320(at)salidaco.com Guest
Posted: Fri Sep 29, 2006 8:26 am Post subject: Your Recommendations Please |
Recently I posted a querry re calibrating my airspeed indicator. After testing and verification there is no doubt my
ASI is simply in error (Its a United 8125 TAS from Van's) so I have decided to replace it.
Now, I would like a digital TAS, but can't find one that is reasonably priced and that would fit in a 3 1/8-inch hole. I can find a MGL digital but it is only an 'indicated' ASI.
I could simply replace the present United with another, but I really like digital.
I also has some hesitation (don't really know why) about using a non-TAS unit.
Fire away..I need fodder to support a decision.
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Fri Sep 29, 2006 2:07 pm Post subject: Your Recommendations Please |
Do you appreciate that the primary ASI must show IAS or better CAS?
If it didn't then the colour speed markings would need to be adjustable
for pressure and density altitude.
TAS is a useful figure for other purposes but does not help in doing the
job of piloting the aircraft. It is also a tricky number to determine
accurately.
Queue Kevin H for complete & more accurate answer....
Doug Gray
On Fri, 2006-09-29 at 10:25 -0600, John Fasching wrote:
| Quote: | Recently I posted a querry re calibrating my airspeed indicator. After
like digital.
non-TAS unit.
av.8(at)bigpond.com Guest
Posted: Fri Sep 29, 2006 11:30 pm Post subject: Your Recommendations Please |
Hi Bert,
I also don't have any increase in rpm prior to engine cutting out using the
mixture control. My O-320 runs sweet and idles smoothly at 600 rpm with
metal FP Sensenich prop. But you have to be sure that pulling the throttle
back when landing that the engine doesn't die. In setting the mixture
screw, I simply adjusted it in and out until the engine idled smoothly,
erring if anything on the lean side. If I had of adjusted it on the rich
side then I may have got the rpm increase Lycoming suggest, but it is not a
problem. Obviously doesn't seem to be one for you either..
Cheers
Martin in Oz
