bo124rs(at)hotmail.com Guest
Posted: Fri Sep 29, 2006 3:49 am Post subject: 0-360 kit for sale, $12,900. |
Another 0-360 kit for sale. $12,900 with $5,000.00 deposit to hold.
Phone 859 369-7582 or cell 859 625-2844
CRANK-RE-CONDITIONED RODS .003 MAINS .010
CASE-CERTIFIED
CASE THROUGH BOLTS-NEW
RODS-RE-CONDITIONED BALANCED WITHIN 2 GRAMS WITH NEW NUTS
CAM-CERTIFIED
CRANK GEAR AND BOLT-NEW
IDLER GEARS-CERTIFIED
LIFTER BODIES-NEW
HYD & SOCKETS-NEW
MAGS AND HARNESS WITH PLUGS-NEW
MAG GEARS BOTH IMPULSE & NON IMPULSE-NEW
CYLINDERS/PISTONS/PINS/RINGS-CERTIFIED WITH NEW PARTS. PISTONS 9:5:1
CYLINDER HOLD DOWN NUTS-NEW
SUMP & PIPES
ACC. COVER
OIL PUMP HOUSING AND GEARS-NEW
ROCKER ARMS- RE-BUSHED
PUSH TUBES-NEW
PUSH RODS-NEW
STARTER/ALT/FLYWHEEL KIT-NEW
TAC SHAFT-NEW
CARB-CERTIFIED
GASKET SET NEW
BEARINGS-NEW
HARDWARE BOLT KIT-NEW
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
O 360 A1A, C/S C2YK-1BF/F7666A4
http://rvflying.tripod.com/id30.html
All-in-one security and maintenance for your PC. Get a free 90-day trial!
http://clk.atdmt.com/MSN/go/msnnkwlo0050000001msn/direct/01/?href=http://www.windowsonecare.com/?sc_cid=msn_hotmail
