rparigor(at)SUFFOLK.LIB.N Guest
Posted: Sun Sep 24, 2006 3:20 pm Post subject: Best wiring techniques to use? |
Need a bit of help to determine best wiring techniques to use.
This is for a Europa XS/Rotax 914 and B+C SD20S/LR3C, start point for
schematic was Z13/8.
Battery is 10 feet behind motor, Flaming River mechanical battery cut off
switch 3 feet ahead of battery aft side of passenger headrest.
http://www.flamingriver.com/index.cfm?ptype=article&article_id 2
1) I am looking to use #4 MIL-W-22759/16 Tefzel wire for battery and
ground. There will be approx a 3 foot run of unprotected wire to the
battery cut off switch. Is there any extra protection that would be
prudent to incorporate? Some sort of robust sleeve on 1 wire, or a fusible
link? Or just not worry about it (not run too close near anything that
conducts)? I have the heavy duty Rotax starter, supposedly draws less amps
than old style, old style starter draw was I think 60 amps, not sure what
momentary is.
2) I need to somehow get power and ground to 2 fuel pumps, wingtip
Strobe/Position LEDs and pitch servo. The headrest is approx 6 feet closer
to the battery (14 foot round trip) compared to the firewall mounted
ground and main bus. If I put a mini power and ground bus in or near the
headrest, would I be negating the concept of single point ground? Would
stealing power from the NO side of the battery cut off likely cause any
noise or other problems? Or just make extra runs from firewall?
3) Would it be advisable to series the battery cut off with the negative
or positive? Reason? I don't have any science to back this up, but I read
that when making model electric aeroplane battery packs, if you need to
make one lead longer than the other, make the negative longer than the
positive, it can help with black wire disease (what I have always done)??
Overall scheme, plenty more time will be spent with battery cutoff opened.
4) I will need to somehow break into the #4 battery wire not going to the
battery cut off switch. Instead of cutting the wire and putting on a lug
on each side, and screwing them back together along with an additional #10
wire ring, could I carefully strip, lets say an inch of insulation off the
#4, and strip 3" off the #10, then strip back the #10 to 1" except for 2
strands, then wrap the 2 strands over the 1" of #4 and 1" of #10 and
solder/heat shrink? I would use the adhesive lined heat shrink.
5) What is good practice to follow, the number of lugs I can stack on the
NO side of the battery cutoff switch stud?
6) I forget the exact diameter of the NO side of the battery cutoff switch
stud, lets say it is 5/16". If lets say I wanted to stack a #4 and a
#10,is it acceptable to stack a ring terminal that has a smaller footprint
on top of one with a larger footprint? Or in this instance because loss of
this connection can cause loss of main and e-bus, use the same size lug,
make a brass insert and crimp/solder in the smaller wire?
7) The Flaming River switch has copper threaded studs, came with a brass
nut and brass lock-washer. Would it be advisable to use a Phosphor bronze
star washer instead of the brass lock-washer?
Ron Parigoris
nuckollsr(at)cox.net Guest
Posted: Thu Sep 28, 2006 5:02 am Post subject: Best wiring techniques to use? |
At 11:19 PM 9/24/2006 +0000, you wrote:
No
| Quote: | Some sort of robust sleeve on 1 wire, or a fusible
momentary is.
It's a plastic airplane . . . don't worry about it.
| Quote: | 2) I need to somehow get power and ground to 2 fuel pumps, wingtip
Minimize the numbers of busses. Run from the firewall.
| Quote: | 3) Would it be advisable to series the battery cut off with the negative
Either way.
| Quote: | 4) I will need to somehow break into the #4 battery wire not going to the
That will cause some folks to roll their eyes back and
mumble unkind things about you . . . but there's nothing
wrong with the physics or failure modes and is probably
a more reliable joint (low parts count, no threaded fasteners).
| Quote: | 5) What is good practice to follow, the number of lugs I can stack on the
Depends on stud length. You need to see one full thread
on the OFF-side of the nut when the joint is finished.
| Quote: | 6) I forget the exact diameter of the NO side of the battery cutoff switch
At the current levels you're dealing with, surface areas are
not going to be an issue so much as joint make-up forces. Torque
the nut down to about 1/2 the value recommended for steel of
the same size/thread.
| Quote: | 7) The Flaming River switch has copper threaded studs, came with a brass
If the lockwasher is the typical automotive split-ring
variety, pitch it an forget it. If it's an internal toothed
lockwasher, leave it in the makeup of the joint but if you're
running out of stud length, leave it off and use some non-
permanent locking guckum on the nut. E-6000 adhesive works
nice. It extrudes out of the hi-pressure contact areas between
threads and nut but keeps the nut secure for vibration induced
loosening. Finally, not so strong a grip as to keep the nut
from being removed.
Posted: Thu Sep 28, 2006 10:46 am Post subject: Best wiring techniques to use? |
Hello Bob
"Need a bit of help to determine best wiring techniques to use."
Much appreciate your input.
Sincerely
Ron Parigoris
Posted: Sat Sep 30, 2006 9:38 am Post subject: Best wiring techniques to use? |
At 06:41 PM 9/28/2006 +0000, you wrote:
Hello Bob
Sincerely
Ron Parigoris
That's a REALLY broad question . . . something akin to
"tell me what you know". If you can articulate more
definitive concerns, I and many others here on the List
will try to be of assitance.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
Posted: Sat Sep 30, 2006 10:19 am Post subject: Best wiring techniques to use? |
Hello Bob
Sorry for the confusion, I was thanking you for answering my 7 questions
on 09-24-06.
Sincerely
Ron Parigoris
On Sat, Sep 30, 2006, "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> said:
>Hello Bob
>Sincerely
>Ron Parigoris
No
momentary is.
Either way.
from being removed.
oldbob(at)BeechOwners.com Guest
Posted: Sat Sep 30, 2006 11:27 am Post subject: Best wiring techniques to use? |
Good Afternoon All,
I noted the reference to using a brass bolt as a
firewall penetration point and ground. The particular
reference is on Z-15, View A.
That all sounds good to me!
What I have not been able to find is a source for the
proper brass bolt. The best I can find is
McMaster-Carr. They list both brass and silicon bronze
bolts, but only in the coarse thread versions. I
rather thought it might be better to use a finer
thread.
Any thoughts?
I had in mind a 3/8-24. All they list is 3/8-16.
Is there a handy reference to the use of the brass
bolt for the grounding function which would include
any recommendations as to washers and nuts to be used
with the brass bolt?
Does anyone prefer a bronze bolt?
What type locking mechanism is most commonly used? Any
problem mixing up steel and brass?
That is, could I use a brass or bronze bolt with a
steel elastic stop nut?
I am sure 'Lectric Bob has a shop note somewhere that
will tell me all this, but my search (as inelegant as
my searches are) has not yet located the guidance I
desire.
Any help greatly appreciated.
Happy Skies,
Old Bob
Stearman N3977A
Jim Baker
Posted: Sat Sep 30, 2006 12:23 pm Post subject: Best wiring techniques to use? |
| Quote: | What I have not been able to find is a source for the
thread.
I don't see that fine thread is any more desireable than coarse in
a conductivity sense.
http://tinyurl.com/faxe8
Try these folks and take a look at threaded brass or bronze
rod. Shoot, you can even get brass castle nuts here....; )
Jim Baker
580.788.2779
Elmore City, OK
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Sat Sep 30, 2006 1:38 pm Post subject: Best wiring techniques to use? |
Hey, Bob!
I don't know if these guys will sell you just the bolt, but it couldn't hurt
to ask...
http://www.bandc.biz/GroundBlock.html
Posted: Sat Sep 30, 2006 2:09 pm Post subject: Best wiring techniques to use? |
Good Afternoon Bill,
Thanks for the heads up. Just goes to show how poor my
search efforts were. B&C was one of the places I
looked before I asked the list!
Happy Skies,
Old Bob
--- Bill Denton <bdenton(at)bdenton.com> wrote:
Denton" <bdenton(at)bdenton.com>
Hey, Bob!
to ask...
Posted: Sat Sep 30, 2006 2:13 pm Post subject: Best wiring techniques to use? |
At 04:36 PM 9/30/2006 -0500, you wrote:
Yes, I believe they will . . . at least they used to.
I understand the coarse thread "dilemma" . . . that
just smacks a lot like automotive. However, fine thread
brass is not easy to find in the wild. I have no problems
with coarse. Just torque the final setup appropriate to
the material and thread. Before putting the last nut on,
wipe the treads with a little E6000 before installing
the last nut. It will be just fine. It's PRESSSURE in the
joint that gets you gas-tight. Thread-locking the nut
will make sure the pressure stays there. And yes, 3/8
would be better than 3/16.
