CardinalNSB(at)aol.com Guest
Posted: Mon Oct 02, 2006 8:15 am Post subject: Glowing LED Warning Lights, Too Dark Now-LM317 |
| Quote: | MikeEasley wrote:
My LED voltage warning lights are now too dark to see in daylight after
adding the resistors in the drawing.
Smaller resistors? | I have been "playing" with leds on a breadboard, controlling them with a LM317. The LM317 supplies constant voltage, determined by a resistance to (the control leg, I don't know the real term). I have used a rheostat and been able to control multiple or single leds, from very bright to very dim/off. I am planning to make an annunciator for a 300xl gps, which always has 2 leds on, sometimes 3, sometimes 4. I have the LM317 between the battery positive and the leds, the leds taking power from the LM317 with their other leg grounded. The leds are in parallel.
A value to me of the LM317 is to be able to maintain constant brightness of multiple leds (I plan to use all the same white leds with colored lenses for colors). The LM317 is from Radio Shack and I have only used the circuit on the back of the box-LM317, a resistor, and a rheostat, 3 parts. Could I wire a backup with a zener diode for a constant brightness?
However, I have been told this LM317 won't work, that I need Pulse Width Modulation. I'm not sure why, the LM317 seems to do what I want at least on my desk at home, is cheap and low parts count. I would appreciate any reasons this would not be a proper way to control multiple identical leds-rf production? Skip Simpson
klehman(at)albedo.net Guest
Posted: Mon Oct 02, 2006 6:36 pm Post subject: Glowing LED Warning Lights, Too Dark Now-LM317 |
The brightness of an LED is proportional to the current going through
it. You need a resistor in series with each LED to limit the max
current and max brightness. Connecting all those resistors to the output
of your LM317 should do what you want. When you dim (lower the voltage
ouput of the LED) there will be less voltage drop through each resistor
and the brightness will reduce. That brightness should not change
regardless of how many LED's are on because each LED has its own
resistor. I think that is your answer - a separate resistor for each
LED. Of course with this description, it is assumed that individual
LED's are turned on by connecting its negative lead to ground.
Ken L.
after
Smaller resistors?
are in parallel.
