Jim Baker
				 Posted: Thu Sep 21, 2006 6:04 pm    Post subject: Manifold drain question..... |
				OK folks...another puzzling mystery. Found the following on the
 following site.....
 http://www.fwshome.com/baroneduc.html
 ___________________________________________
 Several of the intake manifold drain line checkvalve balls
 were missing from their seats on each engine. These are
 sucked closed by the vacuum within the intake runners as
 the engines are operating (remember that 15 " showing as
 manifold pressure is really a partial vacuum to the extent of
 the difference between the 15" on the gauge and the ambient
 pressure at the aircraft's altitude). When we replaced the
 checkvalves, the right engine went smooth as butter, but the
 left remained rough.
 When I was replacing the intake drains in my rebuilt
 IO520K (scavenged from the old engine) they were just AN
 fittings with either hose runs to the firewall/nosewell or just
 a short length of AL tube. Are we supposed to have check
 balls in the drain valves? Keep in mind the above quote was
 from a Baron running IO470s, no turbos.
 We recently had a discussion about something related to the
 induction system on a Bellanca list but I was convinced then
 that my setup was normal...now I'm not so sure. A lot can
 happen to an airplane over the years. I'll also ask Bellanca
 and TCM in the morning....
 Thanks.
 Jim Baker
 580.788.2779
 Elmore City, OK
  |  | - The Matronics Engines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Engines-List |
