		rv8vator(at)comcast.net Guest
				 Posted: Wed Sep 20, 2006 11:46 am    Post subject: T-3 FIREFLY |
				Slingsby did extensive tests on the Firefly fuel system, both standard and
 modified.
 They could not duplicate any problem.
 My feeling is that at least two of the accidents were due to pilot error.
 The Firefly is used the world over for initial flight training. No one else
 has complained about the airplane.
 The USAF did not mothball the airplanes. They were left to sit out in the
 open with absolutely no protection from the elements.
 I had hoped to get a few of these aircraft into A&P Training schools, but
 the USAF destroyed them without any notification whatsoever.
 Martin Sobel
  |  | - The Matronics Engines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Engines-List |
		dodsond(at)qnet.com Guest
				 Posted: Thu Sep 21, 2006 4:12 am    Post subject: T-3 FIREFLY |
				The Air Force considered carefully several options over a period of 10 years
 what to do with the T-3A following the three fatal mishaps.  There were
 several action groups (one called, get this, "Mothers Against T-3's") that
 took legal action against the USAF to stop flying the planes.
 During this period, the aircraft was extensively ground and flight tested at
 Edwards AFB and other places.  Edwards recommended returning the aircraft to
 service, but leadership decided the legal risk was too high.  Several Air
 Force Chiefs of Staffs over the years reviewed the situation.  Twice there
 were studies done to see if there was another use for the aircraft in the
 USAF.  None were found.  The utility of the aircraft just wasn't there for
 anything but primary training.  Due to the litigation, scrapping was
 approved again.
 The liability issue is far reaching in the USAF leadership.  The decision
 was not impulsive and it was backed up by a series of senior leaders over a
 long period of time.
 I was not directly involved in the testing at Edwards, but I worked on other
 concurrent projects with those that were.  There is indeed some utility of
 the aircraft outside of the USAF, but the cost to operate them would make
 them non-competitive with other models of aircraft.  The engines are, in my
 opinion, a sad loss to the civilian community, but again, the liability
 issue was very worrisome.  The dollar cost to the Air Force for scrapping
 rather than selling the parts is not significant.  The expense to
 effectively sell the stuff would offset the majority of the income.  The
 money saved would be lost in the first attempt at legal action against a
 government so uncaring that they would sell killer aircraft parts to the
 unwary public.
 Disappointing, but blame the litigious society as much as Government
 inefficiency.
 -Doug Dodson, Lt Col, USAF (ret)
 Flight Test Engineer
		Speedy11(at)aol.com Guest
				 Posted: Thu Sep 21, 2006 6:37 am    Post subject: T-3 FIREFLY |
				Martin,
  You're right.  The original airplane didn't have enough power so the USAF asked for more powerful engines.  That caused a cooling problem and a CG problem.  Those were never fully resolved but they flew the planes (my son trained in one).  My son said the planes flew oddly.
  The accidents were pilot error - although some contribution goes to the airplane (as reconfigured by the USAF) because it requires so much attention from the pilot.
  As a retired USAF fighter pilot, I'm embarrassed at how the USAF handled this situation.  However, a good portion of the blame goes to our tort system because the USAF is completely destroying the airplanes in order to avoid any liability.  Our current system of law is totally out of whack.
  Stan Sutterfield
   	  | Quote: | 	 		  My feeling is that at least two of the accidents were due to pilot error.
 has complained about the airplane. |
		GrummanDude
				 Posted: Thu Sep 21, 2006 8:46 pm    Post subject: T-3 FIREFLY |
  _________________ Gary
AuCountry Aviation
Home of Team Grumman |
		GrummanDude
				 Posted: Thu Sep 21, 2006 9:30 pm    Post subject: T-3 FIREFLY |
				I did some of the testing at Edwards regarding the propulsion system.
 Whoever installed the 540 overlooked a lot of little things regarding
 fuel delivery. 'nuf said.
 Also, we were told that the students were instructed NOT to lean and to
 treat the plane as if it were a jet ... i.e., single lever: the
 throttle. Flying at the Springs at density altitudes into the teens
 without leaning is poor instruction at best. I think the T-3A could
 have been fixed and flown as a trainer by a competent instructor.
 there, that's better.  Sorry for the confusion.
AuCountry Aviation
		glcasey(at)adelphia.net Guest
				 Posted: Fri Sep 22, 2006 4:29 am    Post subject: T-3 FIREFLY |
				I'd sure like to know what those things were that were "overlooked" in the design of the fuel delivery system, having just designed one for my 540.  Can you share that bit of knowledge?
 Gary Casey
 Lancair ES, IO-540
 system.  Whoever installed the 540 overlooked a lot of little things
 regarding fuel delivery.  'nuf said. [b]
				 Posted: Fri Sep 22, 2006 9:31 am    Post subject: T-3 FIREFLY |
				All true... the operation of the aircraft was abominable.  The engine
 installation needed work, but was not flawed beyond repair.
 It took a lot of political pressure to get the USAF to accept the T-6A (a
 turbo-prop) to replace the T-37 (a pure jet) for primary training at UPT.
 That culture is finally fading from the USAF, but not quickly.  I strongly
 believe the T-3 mishaps and incidents were a directly a result of forcing
 pilots to fly it that were trained not only on pure jet equipment but also
 with the attitude that non-jets were beneath them.  The aircraft were not
 respected by mid-level leadership, and so that rubbed off on the pilots.  I
 know some felt they were being "left out" of the "real Air Force".  Their
 approach to the mission reflected that.
 Still, the planes were goofy as you said.  The USAF also got Slingsby to
 re-configure the cockpit so the primary pilot seat was on the right... so
 the mid-cockpit throttle would be in the left hand.  Ridiculous.  If given
 one of the aircraft, I would take out the instruments, radios and other such
 goodies, remove the engine and propeller, and scrap the airframe.  Not that
 it was unsafe, but it didn't fly "well".  It was a dog performance-wise.
 -Doug Dodson
 Edwards AFB 1998-2006
		jboatri(at)emory.edu Guest
				 Posted: Fri Sep 22, 2006 1:05 pm    Post subject: T-3 FIREFLY |
				So we've now had several people in the know tell us that the airplane
 had problems, many of them brought on by the USAF higher-ups. The
 USAF brass does the dirty deed (maybe they took lessons from
 Chicago's Mayor Daley?) and then blames it on potential torts.
 Hm.
 I'd find them more believable if: 1) there was a history of similar
 suits (there's an awful lot of military surplus equipment out there -
 googling finds no cases brought against the feds due to selling Joe
 Civie something that ended up killing him) and 2) if they didn't have
 such a vested interest in making this all go away, what with being
 (apparently) part of the original problem and then remaining
 aggressively stupid about dealing with it.
 There may be tons of surplus equipment tort cases out there
 justifying blaming the litigation boogey man, so apologies if I
 missed them. And apologies in advance if this opinion offends tender
 sensibilities, but this sure smacks of classic CYA.
 My less than two cents. Have great weekend, I'm off to fly the Piet!
 _____________________________________________________________
 Jeffrey H. Boatright, PhD
 Associate Professor, Emory Eye Center, Atlanta, GA, USA
 Senior Editor, Molecular Vision, http://www.molvis.org/molvis
 mailto:jboatri(at)emory.edu
		GrummanDude
				 Posted: Fri Sep 22, 2006 8:36 pm    Post subject: T-3 FIREFLY |
				My Commander at Edwards was on the board that approved it. He tried to
 talk the committee out of getting it, saying existing planes like a
 T-34 would be cheaper and it was a known quantity from a certified
 supplier. He was out voted.
  Gary Vogt
 Edwards AFB, 1982-1998
AuCountry Aviation
		GrummanDude
				 Posted: Fri Sep 22, 2006 8:45 pm    Post subject: T-3 FIREFLY |
				1.  don't put the gascolator above the exhaust pipe
 2.  use at least 3/8 inch fuel line (not the 5/16 inch stuff like the
 FireFly)
 3.  keep the boost pump as low as practical
   - -  the tests we did at SAIC showed a lot of pump cavitation when the
 pressure at the carb was low
   - - - although the fuel in the float bowl of the carb was probably
 fine.
AuCountry Aviation
		Ed in JXN
				 Posted: Fri Sep 22, 2006 8:48 pm    Post subject: T-3 FIREFLY |
				Well said, Jeff!
 Ed in JXN
 MkII/503
				 Posted: Sat Sep 23, 2006 5:33 am    Post subject: T-3 FIREFLY |
				Thanks very much!  In my design:
 1.  The gascolator is mounted in a cooled box at the bottom center of the firewall (not above the exhaust pipe as it is on some Lancairs)
 2.  3/8 fuel line used  (almost went to 1/2 inch, but didn't).
 3.  Electric pump is at the lowest point in the whole fuel system.
 I was afraid that what they "overlooked" were esoteric details that I might have missed.   Looks like they ignored the obvious.
 Gary Casey
 From: teamgrumman(at)aol.com (teamgrumman(at)aol.com)
 --> Engines-List message posted by: teamgrumman(at)aol.com (teamgrumman(at)aol.com)
 FireFly)
 fine. [b]
				 Posted: Sun Sep 24, 2006 4:07 pm    Post subject: T-3 FIREFLY |
				CYA doesn't wash because the "A" that bought the aircraft is long gone, and
 no less than three subsequent Air Force Chiefs of Staff came to the same
 decision after reviewing the situation (as it evolved) over a long period of
 time.  They were no doubt advised by their respective JAG officers as well
 as MAJCOM commanders, contracting officers, financial officers, ... In the
 big scheme of things, more resources were spent trying to get the aircraft
 to work physically and politically than the darn things were worth.
 Considering how much military equipment has been retired over the years,
 there really isn't all that much in civilian hands.  For aircraft at least,
 most individuals that own a warbird got it from a third party such as a
 foreign government or a military contractor that acquired the machine in
 service of the government.
 -Doug Dodson
				 Posted: Sun Sep 24, 2006 4:22 pm    Post subject: T-3 FIREFLY |
				Doug,
 Is it that you're arguing institutional CYA doesn't exist?
 Jeff
 time...
 Jeffrey H. Boatright, Ph.D.
 Associate Professor
 Department of Ophthalmology
 Emory University School of Medicine
 Atlanta, GA 30322
 Editor-in-Chief
 Molecular Vision
		Jim Baker
				 Posted: Sun Sep 24, 2006 4:25 pm    Post subject: T-3 FIREFLY |
				 	  | Quote: | 	 		   They were no doubt advised by their respective JAG officers as well
 Wonder how quick they'd shut down sales of Continental
 engined ground power units if they knew the engines were being
 pulled and modded for aircraft use......
 Jim Baker
 580.788.2779
 Elmore City, OK
		Ed in JXN
				 Posted: Sun Sep 24, 2006 5:06 pm    Post subject: T-3 FIREFLY |
				Doug,
         You must admit the tactics used in the Firefly disposal are pretty
 unusual for what should otherwise be a relatively minor matter.  CYA isn't
 all that uncommon in the military and the Air Force-imposed mods to the T-3,
 and the ensuing complications, make CYA all the more plausible.
 Ed in JXN
				 Posted: Mon Sep 25, 2006 4:59 pm    Post subject: T-3 FIREFLY |
				The T-3 hardware is a minor matter to the USAF in financial terms.  I am
 convinced someone would actually sue the DoD for simply selling the parts to
 the public.  No failure has to occur.  This potential implies that simply
 scrapping the hardware is the smart and simple way to go.  I know of more
 than one homebuilder who scrapped his own aircraft when he was done with it
 rather than sell it.
 -Doug Dodson
				Uh, OK.   Maybe there is such a thing, but the DoD is not a college football
 alumni association.  What would be the driving motivation for "institutional
 CYA"?  Why would a person make a decision to protect an institution as fast
 changing as the military?  In my experience, my leaders considered first
 what is best for the mission, and so long as that criteria is met, what is
 best for the education and morale of the workforce. CYA certainly exists but
 it doesn't seem to span the length of a tour of whomever is involved.
 Safety IS the primary motivation for CYA decision making.  The USAF may be
 the second most risk-averse government agency, right after NASA.
 Just my observations and opinion.  Maybe I'm just naive.
 -Doug Dodson
				 Posted: Mon Sep 25, 2006 5:46 pm    Post subject: T-3 FIREFLY |
				Doug,
 I'd say procurement is probably one of the top reasons for
 institutional CYA. Misguided pride is another (where one gets the
 actions of the organization confused with one's self-perception - I
 feel bad when Emory University gets dinged. Why? I wasn't the one who
 did x, y, or z. But I still feel bad.).
  From my POV, which is not based on military experience, but rather a
 little (a little) experience with large organizations both private
 and public, there is a vast distance between those who get the job
 done (people who you describe, I think, very aptly) and people who
 set top level and long term policy. They often are the ones who are
 looking to the budget for the next decades and "legacy". At that
 level, regardless of who did what on any one project, if the
 organization gets dinged, the organization's future is threatened.
 Thus, sweep stuff under the rug, make sure the long term budget is
 safe.
 As for being naive, I apologize if I was condescending. I don't think
 you're naive, I think that you and I were just talking at cross
 purposes and I tend to be a smart-ass. But I'm working on toning it
 down!
 Jeff
 -Doug Dodson
 Associate Professor
 Atlanta, GA 30322
 Editor-in-Chief
 Molecular Vision
				 Posted: Tue Sep 26, 2006 7:19 pm    Post subject: T-3 FIREFLY |
				Quote: I'd say procurement is probably one of the top reasons for
 institutional CYA. Misguided pride is another...
 I agree with the second reason (hence my football reference), but I really
 don't see much of that in the military on an institutional level.  Too much
 oversight at all levels.  The inclination may be there, but it gets overcome
 by competing criteria.
 Procurement?  Certainly a tough game in the military, and one where MANY
 rather embarrassing mistakes are made.  But the T-3 had already brought that
 humiliation to the institution.  Selling them would have opened the door for
 more of the same, more so than the scrapping IMO.  I could be construed as
 CYA to sell the aircraft to reduce the waste just as much as CYA to scrap to
 prevent further embarrassment (not even considering the potential for actual
 damage to the buyer).
 FYI, Edwards just sent a team to Iraq to see why a Comp-Air 7 (highly
 modified to include tricycle landing gear and a turboprop) that belonged to
 the Iraqi Air Force crashed.  The investigation and flight test done on the
 remaining fleet pointed to scrapping those aircraft too.  Guess what, from
 VERY high up it was declared that we would fix the aircraft.  The reason was
 of course political.  The State Department wants it to look like we are
 helping the Iraqis, not carrying them.  It would have been easier and
 cheaper to just give them some C-12's and T-34's to replace their POS
 aircraft, but no!  Well, some time later, the project appeared to be near to
 being scrapped (so to speak).  I really don't know the final status as I
 retired several months ago and the project was still not quite dead.
 -Doug Dodson
