hagargs(at)earthlink.net Guest
gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Tue Sep 26, 2006 6:52 am Post subject: Flying is good! |
Hey Steve thats fantastic!
On my mono, 18 lbs tire pressure turns it into a C172 for landing.
Anything more and it
turns into a squirrely ass POS! I really think it has a lot to do with
outrigger height off the
ground. If you always get the tailwheel down first, then the wing is done
flying and the
outriggers will be closer to the ground as the wing is no longer flexing up,
allowing less
shenanigans on the roll out. My outriggers just barely touch the ground
sitting on the tarmac with no load. I find too that with a passenger, the
outriggers are even lower and landings are a
yawner.
Glenn
[quote]From: "Steve Hagar" <hagargs(at)earthlink.net>
Reply-To: europa-list(at)matronics.com
To: "europa-list" <europa-list(at)matronics.com>
Subject: FW: Flying is good!
Date: Tue, 26 Sep 2006 21:40:04 -0700
Steve Hagar
n100rh(at)sbcglobal.net Guest
Posted: Tue Sep 26, 2006 7:01 am Post subject: Flying is good! |
Steve,
Dave Anderson,( xs914 motorglider Minden, NV), he was quick to point out
tire pressure could be a problem. He said, high pressures would
contribute to wild handling on landings and that lower tire pressures
greatly improved the situation. I will fwd your note on to him, he no
longer follows the list, so he can get back to you with his findings.
Ralph
Steve Hagar wrote:
Steve Hagar
hagargs(at)earthlink.net <mailto:hagargs(at)earthlink.net>
Posted: Tue Sep 26, 2006 8:31 am Post subject: Flying is good! |
Glenn
lower tire pressure means a bigger slip angle on the ground and that
will make the initial grab in yaw less agressive also. I think you'r
right about the outriggers, less wobble when they are both firmly on the
ground.
Graham
GLENN CROWDER wrote:
Quote: |
<gcrowder2(at)hotmail.com>
with outrigger height off the
done flying and the
flexing up, allowing less
ground sitting on the tarmac with no load. I find too that with a
passenger, the outriggers are even lower and landings are a
yawner.
Glenn
scrimm
Joined: 09 Jan 2006 Posts: 81 Location: Gilbert, SC SC99
Posted: Tue Sep 26, 2006 3:06 pm Post subject: Flying is good! |
So what would be the minimum air pressure? Max of 18 and a minimum of ???
Steve
N42AH
--> <grahamsingleton(at)btinternet.com>
Glenn
lower tire pressure means a bigger slip angle on the ground and that will
make the initial grab in yaw less agressive also. I think you'r right about
the outriggers, less wobble when they are both firmly on the ground.
Graham
with outrigger height off the ground. If you always get the tailwheel
down first, then the wing is done flying and the outriggers will be
closer to the ground as the wing is no longer flexing up, allowing
less
passenger, the outriggers are even lower and landings are a yawner.
Glenn
_________________ Steve Crimm
N42AH |
Posted: Tue Sep 26, 2006 4:21 pm Post subject: Flying is good! |
17 psi? :-[
Graham
Steve Crimm wrote:
Steve
N42AH
SPurpura(at)aol.com Guest
Posted: Tue Sep 26, 2006 4:55 pm Post subject: Flying is good! |
I tried 18 psi and found it too mushy for me. I inflate to 24psi,have 360hrs on the same tire & original tube, no problem yet. Sam N77EU [quote][b]
96victor(at)gmail.com Guest
Posted: Tue Sep 26, 2006 5:32 pm Post subject: Flying is good! |
So maybe the problem is not the air pressure but as Glen suggest it is the outriggers distance from the ground? Suspicious!
Tom
On 9/26/06, SPurpura(at)aol.com (SPurpura(at)aol.com) <SPurpura(at)aol.com (SPurpura(at)aol.com)> wrote: [quote] I tried 18 psi and found it too mushy for me. I inflate to 24psi,have 360hrs on the same tire & original tube, no problem yet. Sam N77EU
nwcmc(at)tiscali.co.uk Guest
Posted: Tue Sep 26, 2006 10:13 pm Post subject: Flying is good! |
Also watch for brake calliper rubbing against tyre sidewall especially
during turns. If this happens it will leave a mark on the side of the
tyre.
Nigel Charles
ward.t(at)xtra.co.nz Guest
Posted: Tue Sep 26, 2006 10:34 pm Post subject: Flying is good! |
Likewise Sam, 18psi is too little and props too close to ground. I have mine at 26 psi. No control problems.
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Ph +64 3 3515166
Mobile 021 0640221
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
