Erich_Weaver(at)URSCorp.c Guest
Posted: Tue Sep 26, 2006 3:49 pm Post subject: cant wire p-mags using a single switch? |
This was posted on the Vans airforce forum recently by an individual that
could not get his p-mags working. After having sent it back to the
factory, this is what he reports:
"My dead P mag worked great back at the factory.
Then I had a brain wave.
I had tried to combine the off-power fail test-Run modes onto one DPDT
switch.
Unfortunatly there is a momentary change in state when you go from OFF to
one of the other states.
What happens is the Pmag becomes ungrounded before it gets power.
This does not work...You have to have a seperate switch for the PMag power
fail.Preferably a normally closed momentary switch"
After a request from a reader asking for further elaboration, this was the
reply:
"Its not when you lose ground...The P lead is UNgrounded in flight.
Its no big deal in terms of flying. I.e when your cruising along the PMag
will be ungrounded....If it then loses power it will operate as normally.
I.e not an issue.
The problem is if when starting you Unground the Plead before you apply
power...The Pmag then won't work...At least mine didn't.
As this will never happen in flight its a non issue.
The only reason it was an issue for me was that I combined the OFF-TEST-Run
modes onto a single switch. You cannot do this because no matter how you
wire the switch you will always unground the Plead before you apply power.
Long story short you need a seperate switch to test the power fail
mode...or pull the CB or whatever.
Right now I just have the power connected permanently...I.e no way to test
it (unless I pull the fuse) .
I want to find a normally closed momentary switch that I can't leave in the
OFF postion...Haven't found one yet."
As I have wired my p-mags using a single switch per Bobs Aeroelectric
Connection, but have not start tested the engine yet, I am concerned. Does
the above make any sense? Surely someone has successfully followed the
'Connection schematic before and NOT had this problem ?
Erich Weaver
nuckollsr(at)cox.net Guest
Posted: Tue Sep 26, 2006 5:49 pm Post subject: cant wire p-mags using a single switch? |
At 04:47 PM 9/26/2006 -0700, you wrote:
<snip>
| Quote: | As I have wired my p-mags using a single switch per Bobs Aeroelectric
The anecdote quoted doesn't offer much clarity for the
issue because there are no schematics offered nor part numbers
of the switches used.
The switches shown in the Z-figures are progressive transfer
devices that offer specific performance in terms of what happens
each time the toggle is moved. Further, the schematics I've
published are CONTRARY to factory recommended p-mag wiring
which is discussed on page Z-6 of:
http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf
The reason for the variance is that from the pilot's perspective,
I want to know that a P-mag's internal alternator is
functioning during run-up so moving the p-mag switch from
full up to mid position needs to interrupt battery power.
Wiring as shown does NOT offer an ability to power up
a p-mag with the ignition function disabled for the purpose
of using built in timing tones or setting the prop for
hand cranking. From the systems designer perspective, I
chose to favor the pilot and add the third maintenance
switch so that rarely conducted operations that use
battery power with the ignition function disabled may
be accomplished.
