Exhaust Springs
pulsair(at)mindspring.com
PostPosted: Sun Sep 24, 2006 4:39 pm    Post subject: Exhaust Springs Reply with quote
I just purchased four springs from John McBean. Mine were wearing through. Changed them at the annual. The price was very reasonable. Throw some business John's way. Also, run safety wire inside the spring. Jeff Classsic IV
brodg(at)texas.net
PostPosted: Mon Sep 25, 2006 3:33 am    Post subject: Exhaust Springs Reply with quote
The springs most typically wear thru at the ends (due to rubbing on the exhaust brackets), not the middle, so safety wire run inside the spring will not help.
Brian
akflyer
PostPosted: Mon Sep 25, 2006 7:03 am    Post subject: Re: Exhaust Springs Reply with quote
this is a pic from an avid I just picked up. It shows what he is talking about o nthe safety wire. It does hold the exhaust together for a little while if the spring breaks. Another thing we do on our race snowmachines is smear high temp RTV on one side of the spring. It keeps alot of the vibtarion and rattling down.
 Filesize:  142.73 KB
 Viewed:  567 Time(s)
Float Flyr
PostPosted: Mon Sep 25, 2006 12:12 pm    Post subject: Exhaust Springs Reply with quote
I run a lockwire up inside my exhaust springs in case one of the springs
breaks it won't be flailing around inside the cowl. It is tied pretty loose
but will hold the exhaust together for short periods of time even if more
than one spring decides to call it quits.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Mon Sep 25, 2006 3:36 pm    Post subject: Exhaust Springs Reply with quote
Brian,
The safety wire is there in case the spring breaks. It is wired to the connectors in side the spring. I guess you had to be there. Jeff
eskflyer(at)lvcisp.com
PostPosted: Mon Sep 25, 2006 5:31 pm    Post subject: Exhaust Springs Reply with quote
You are supposed to safety wire the springs, So when they break the wire keeps all the pieces together and not hsorting or flying around in the cowling , also supposed to put rtv rubber silicone on the spring this helps keep the vibrations down and also keep the pieces together .
John Perry
Kitfox 2 N718PD
582/ subbie
TD/ Straight floats
PostPosted: Mon Sep 25, 2006 5:33 pm    Post subject: Exhaust Springs Reply with quote
Yo bro we think the same hMMMM must be in the genes .
Everyone this is my Brother in Alaska.
Welcome to the list BRO.
John Perry
kitfox 2 N718PD
582/ subbie
TD/ Straight Floats
akflyer
PostPosted: Mon Sep 25, 2006 5:51 pm    Post subject: Re: Exhaust Springs Reply with quote
I was not going to let anyone know I was your brother lol... thanks for letting that cat outa the bag...
JohnBanes(at)adelphia.net
PostPosted: Tue Sep 26, 2006 3:58 pm    Post subject: Exhaust Springs Reply with quote
Thanks Jeff, John
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of jeff puls
Sent: Sunday, September 24, 2006 8:40 PM
Subject: Exhaust Springs
