FLYaDIVE(at)aol.com Guest
Posted: Fri Sep 29, 2006 4:27 am Post subject: battery cables & Relays |
Bob & Gaggle:
I took a look at the picture of the relay installation (see:
http://aeroelectric.com/articles/Battery_Grounds/Battery_Grounds.html )
| Quote: | From my experience I have found that the particular relay design being used
has a failure point ESPECIALLY if installed in the position shown (Cap Side
Down).
The failure point is the rolled over edge. In the construction there is a
rubber gasket between the cap and the can to keep the moisture out. But what
happens is moisture collects in the area between the can and cap lips, rust
occurs and that weakens the bond and moisture seeps its way around and past the
rubber gasket. The failure is internal rust on the solenoid slug (sticking) and
rust on the steel contact brackets (breaking off or bending away from contact).
The two step CURE:
1 - Before installing the relay, seal that area. I did mine by dipping the
entire relay in EPOXY Paint. Of course I masked off the terminals and any
needed ground tap point. (Some relays use the case for Ground. The ones in the
picture are four terminal type and uses one coil terminal as Ground. Others are
three terminal type and use the case as Ground.
2 - Mount the relay so the Cap is facing UP.
We are learning things everyday, I hope. And time is a great teacher.
Unfortunately time is never recoverable and always long in happening. Time taught
me this problem and also this cure.
On the installation of the battery cables as described in the above web link,
do the following:
Install Internal Star Washers between the Ground Point and the washer and
another Internal Star Washer between the Cable Lug and the top washer. Use a
Conductive Grease, on the entire connection.
Why all this? Because from my own experience and that of MANY auto shops
Grounding to aluminum is a major conductive problem. Corrosion occurs and MANY
.. MANY electrical problems can be traced to nothing more than a corroded
Ground connection.
| Quote: | From here on I'm just elaborating so you don't have to read it.
I recently had the following problems on a car:
Engine would over heat when idling.
Transmission would not shift.
Cruse Control would not work.
Battery would not charge.
Alternator would not put out the required voltage.
The CAUSE ... BAD GROUND on the ALUMINUM ENGINE BLOCK.
CURE ... What I mentioned above with the Internal Star Washer.
One connection ... All those problems.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
N6030X(at)DaveMorris.com Guest
Posted: Fri Sep 29, 2006 6:35 am Post subject: battery cables & Relays |
Or maybe you could mount it at a slight angle so that any liquid will
drain off, but you still maintain the resistance to having positive
G-forces wanting to open the contacts, like this (look just below the battery):
http://www.davemorris.com/Photos/Mooney%20N6030X%20Guts%20-%20Firewall%20Fwd/IMG_1799.jpg
Dave Morris
At 07:26 AM 9/29/2006, you wrote:
Bob & Gaggle:
Down).
and past the
(sticking) and
from contact).
The two step CURE:
ones in the
Ground. Others are
do the following:
occurs and MANY
... MANY electrical problems can be traced to nothing more than a corroded
Ground connection.
Barry
"Chop'd Liver"
time."
Yamashiada
nuckollsr(at)cox.net Guest
Posted: Fri Sep 29, 2006 9:36 am Post subject: battery cables & Relays |
At 08:26 AM 9/29/2006 -0400, you wrote:
Bob & Gaggle:
Down).
past the
(sticking) and
contact).
The two step CURE:
in the
Ground. Others are
This style of contactor is not, as you have observed, suitable for
situations where it's likely to be splashed or dripped on. Cessna
went through the "lets seal it up" routine back in early 80s when
the new floating cowl would allow rainwater to run down the front
of the firewall. They tried several techniques to "seal" these devices
with mixed success.
In many cases, attempts to seal only make matters worse. Consider
an airplane sitting out on the ramp on a warm sunny day. A little
shower comes by and sprinkles the "sealed" relay with cool water.
The pressure inside the container goes down due to cooling and
water is sucked into the enclosure through the tiniest hole
(ukum-gukies applied to outside are NOT hermetic seals).
Now, moisture that came in as liquid through the tiny hole
has to escape through the same hole as a vapor under the
influence of atmospheric pressure changes. The end result
for many of Cessna's efforts was that some folks experienced
fewer failures due to moisture, but some had more.
Some years prior to the Cessna experience, I was head
techowiennie for an amateur radio repeater club. We had a
much coveted location on the 1200 foot platform of KTVH
channel 12 over in Hutchinson KS. See:
http://www.aeroelectric.com/Pictures/Misc/KTVH.gif
We gathered up donations totaling about $4000 to buy
a band new Motorola Micore repeater. Great radio, great
location, longest legged repeater in Kansas.
Every time it rained, the repeater went off the
air and took some time to recover. We started a series
of attempts to keep moisture out of the cabinet and
the harder we tried, the longer it took to go off
the air . . . and longer to recover.
Finally discovered that the best bet was to leave the
cabinet well vented to atmosphere and install internal
circulation fans and heaters. Repeater still went off the
air but recovered very quickly when the storm passed.
In the case of our el-cheeso contactors, the first
consideration is keep the water off. If that's not
practical, mount cap-down and drill generous drain
holes in cap (be careful when the drill punches
through).
Somebody mentioned contactor orientation preferences
to offset aerodynamic g-loading on contactor in
flight. There's a great deal of hangar-myth circulating
around out there about contactor compromise due to
g-loads . . . all wrong. If there's a mounting
preference, it will be for the purposes of letting
the water drain out. Attempts to "seal" are problematic
and exceedingly difficult to test.
These contactors have been used since the mid-40's
on all manner of vehicle and been shown to be of
good value . . . but they're NOT sealed and excessive
local moisture is likely to cause problems.
Posted: Fri Sep 29, 2006 9:48 am Post subject: battery cables & Relays |
Bob & Gaggle:
Down).
past the
(sticking) and
contact).
The two step CURE:
in the
Ground. Others are
with mixed success.
through).
Jim Baker
Posted: Fri Sep 29, 2006 12:52 pm Post subject: battery cables & Relays |
| Quote: | They tried several techniques to "seal" these devices
with mixed success.
snip....
| Quote: | (ukum-gukies applied to outside are NOT hermetic seals).
Also known as encapsulation.
Which leads to the question...and perhaps overkill for this
issue...would full-blown potting be a possibility here? Assuming
no detrimental outgassing from the potting material, just make
some pigtail leads from the unit and pot the wires and
connectors as well.
Geeq, I just love making the simple absurd.....
Jim Baker
580.788.2779
Elmore City, OK
Posted: Fri Sep 29, 2006 2:40 pm Post subject: battery cables & Relays |
At 03:49 PM 9/29/2006 -0500, you wrote:
> with mixed success.
snip....
connectors as well.
That's been done! Actually, the last time I saw
that was on a piece of electronics that needed to
run submerged to about 100' of water column. The
tech found some thixotropic RTV and painted the
assembly with several coats . . . with a vacuum
pull on the last coat before it set up. The idea
was that any opening allowing an outgas would bubble
through and releasing the vacuum would suck RTV
into the void.
It looked like it ought to work. Makes 'em
hard to repair!
Posted: Fri Sep 29, 2006 3:44 pm Post subject: battery cables & Relays |
In a message dated 9/29/2006 4:57:52 PM Eastern Standard Time, jlbaker(at)msbit.net writes:
| Quote: | > They tried several techniques to "seal" these devices
| Quote: | with mixed success.
snip....
connectors as well.
Jim Baker
580.788.2779
Elmore City, OK |
Jim:
I am a very firm believer in the K. I. S. S. M. E. principle. Sure potting is a possibility, but what kind of potting and will it adhere any closer or better to the unit than dipped epoxy paint? I doubt it!
ONLY time will tell.
I ... Let me repeat that ... I ... Not "They", I did the simple dipping of the relay in an epoxy paint over 9 years ago and have NOT had a single relay problem since. I am doing the testing and Of course, as I said, only TIME will tell. According to my log books the relay was replace once before. That means I am on the third relay in 33 years. Now, 33 divided 3 is a relay once every 11 years .... Well, ask me how it is doing in three more years. That will equal the previous data, but I'm going for the record and beat that data.
So, Jim, keep making the simple absurd ... It keep the gray matter stimulated. Just don't believe the absurd.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third time."
Yamashiada
Posted: Sat Sep 30, 2006 2:35 am Post subject: battery cables & Relays |
In a message dated 9/29/06 10:41:18 AM Eastern Daylight Time,
N6030X(at)DaveMorris.com writes:
| Quote: | IMG_1799.jpg
Dave Morris
Yes, Dave, the mounting in that picture is very poor and in an exposed area
to many of the elements. In that installation more than moisture ... Water ...
Will collect. Mounting it CAP UP will eliminate the pooling of water and a
little dipping action as I described will take care of the rest.
As for the 'G' forces, well that idea has been kicked around so much it is
like a month old hair ball. <--- I have no idea what that means.
But it is really not an issue. Nothing we do in flying will approach a 'G'
Force or duration that will pull the contacts apart.
W E L L ... Maybe some of the landings I have seen But there again
during that moment I don't think the person is looking for a flickering of the
radios ... Well, maybe they were and that is why the hard landing?
LoL
Barry
"Chop'd Liver"
time."
Yamashiada
Posted: Sat Sep 30, 2006 5:49 am Post subject: battery cables & Relays |
I thought the whole reason for mounting them upside down in the first
place was the g-force issue. Otherwise, it just looks wrong to mount
it with the hat down!! LOL!
Dave
At 05:33 AM 9/30/2006, you wrote:
> battery):
> Dave Morris
... Water ...
flickering of the
LoL
Barry
"Chop'd Liver"
time."
Yamashiada
Bob McC
Posted: Sat Sep 30, 2006 9:54 am Post subject: battery cables & Relays |
Dave;
The "G" forces required to open a closed contactor are generally not
survivable. (or at least very close to it). I don't have quantitative
numbers, but I have tried pulling one open and the force required is VERY
significant. Many, many times that required to close it.
Bob McC
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sat Sep 30, 2006 2:16 pm Post subject: battery cables & Relays |
At 01:51 PM 9/30/2006 -0400, you wrote:
<robert.mccallum2(at)sympatico.ca>
Dave;
Bob McC
Yes, the whole g-forces on contactors thing was bogus from
the get-go. I was at OSH one year when the story went around
about some performer landing with a chewed up ring-gear. The
"story" was that g-forces must have energized his starter
contactor. Odds are that he was thinking really hard about the
show ahead and took off with a stuck contactor.
A study of the accelerations necessary to open a battery contactor
or close a starter contactor just doesn't support the popular
stories.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Sat Sep 30, 2006 3:17 pm Post subject: battery cables & Relays |
So they why does everybody install them upside-down? Has the myth taken hold?
Dave Morris
At 05:15 PM 9/30/2006, you wrote:
<nuckollsr(at)cox.net>
>Dave;
>Bob McC
stories.
Posted: Sat Sep 30, 2006 5:10 pm Post subject: battery cables & Relays |
At 06:14 PM 9/30/2006 -0500, you wrote:
Dave Morris
Absolutely . . . just like avionics master switches.
