harvey4(at)earthlink.net Guest
Posted: Mon Sep 25, 2006 4:45 pm Post subject: Coax connector question |
I'm looking to connect my radio and transponder cables to their
respective instruments (ICOM A200 and Garmin 320A).
I used RG 58 cable for the radio antennas and RG 400 for the
transponder antenna.
When I look at available co-ax connectors there seem to be a host of
different ones - thread on, push on, screw on, compression, "turn and
lock"....I'm totally confused.
Can someone educate me about co-ax connectors, so I might at least
form a picture of what I should be using? I expect there's a rule set
of when to use what.
Many thanks
Neil
wrmaxwell(at)bigpond.com Guest
Posted: Mon Sep 25, 2006 5:19 pm Post subject: Coax connector question |
Cant speak for the transponder Neil but your your Icom A200 expects to see a
BNC co-ax connector heading its way. That's a push on, turn and lock or
bayonet fitting.
Bill---
FLYaDIVE(at)aol.com Guest
Posted: Tue Sep 26, 2006 4:40 am Post subject: Coax connector question |
In a message dated 9/25/2006 9:23:18 PM Eastern Standard Time, wrmaxwell(at)bigpond.com writes:
| Quote: | > Can someone educate me about co-ax connectors, so I might at least form a
| Quote: | picture of what I should be using? I expect there's a rule set of when to
use what.
Many thanks
Neil |
Neil:
Go to GOOGLE, select PICTURES and type in BNC ... You will get lots of hits.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
nuckollsr(at)cox.net Guest
Posted: Tue Sep 26, 2006 5:35 am Post subject: Coax connector question |
At 08:43 PM 9/25/2006 -0400, you wrote:
I'm looking to connect my radio and transponder cables to their respective
I used RG 58 cable for the radio antennas and RG 400 for the transponder
antenna.
use what.
Check through the links below. These describe the materials,
techniques and tools useful to the task of acquiring and
installing BNC connectors on your feedlines.
http://aeroelectric.com/articles/Coax_Stripper/coaxstrip.html
http://aeroelectric.com/articles/BNC_Rt_Angle/BNC_Rt_Angle.html
http://aeroelectric.com/articles/bnccrimp.pdf
http://aeroelectric.com/articles/coaxconn/coaxconn.htm
http://steinair.com/connectors.htm#dsub
http://tinyurl.com/l4no7
http://www.bandc.biz/BNCcrimptool.html
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
