Dennis Jones
Joined: 17 Sep 2006 Posts: 45 Location: Poplar Grove, IL
Posted: Tue Sep 19, 2006 9:46 pm Post subject: Transponder |
What is a strobe input/output for a transponder/encoder?
charlieray(at)optonline.n Guest
Posted: Wed Sep 20, 2006 2:14 am Post subject: Transponder |
Apply a ground to this pin to have the encoder output on all the time. This
is required to be on all the time with every modern transponder.
Charles
Dennis Jones
Posted: Wed Sep 20, 2006 8:40 am Post subject: Re: Transponder |
The transponder schematic shows a suppression OUT pin 1and a EXT. DME suppression IN pin 6. Because I do not have a DME I understand that both of these pins would be empty. Would this be what the encoder schematic is showing as the strobe input? If so then this pin would not be used and would be pigtailed to the fround pin.
Posted: Wed Sep 20, 2006 6:29 pm Post subject: Transponder |
Dennis,
What Transponder and what encoder are you using? Supression I/O is only used
for other L band devices like active traffic (tcas) and DME.... They all
work around 1030-1090 MHZ and the suppression lines are only used so only
one device is active for a split second.
Strobe input at the encoder should be tied to ground, I run my gray code
wires A1, A2, A4, B1...etc and power and ground to the encoder. some
transponders supply switched power out to simplify the wiring to the
encoder. If your transponder has switched power out, thats what I would use
to power the encoder. It does not need its own circuit breaker in general.
I would supply ground to the endcoder by splitting the ground to the
transponder (at the transponder rack) and sending one leg to the encoder.
Then I would take that ground and split it into two at the encoder, one
hooked to the ground pin and the other hooked to the strobe pin. Like I
said before, most all transponders want to see the Gray Code (altitude)
input at all times, and the strobe pin being tied to ground means that the
encoder will always be sending out gray code info.
If Im too confusing or you need more info just let me know.
your avionics guru.
Dennis Jones
Posted: Thu Sep 21, 2006 2:06 pm Post subject: Transponder |
Charles
On the transponder the schematic shows two remote ground pins. What would they
be used for?
Dennis
Quoting Charles Reiche <charlieray(at)optonline.net>:
Dennis,
only used for other L band devices like active traffic (tcas) and
DME.... They all work around 1030-1090 MHZ and the suppression lines
are only used so only one device is active for a split second.
code wires A1, A2, A4, B1...etc and power and ground to the encoder.
some transponders supply switched power out to simplify the wiring to
the encoder. If your transponder has switched power out, thats what
I would use to power the encoder. It does not need its own circuit
breaker in general. I would supply ground to the endcoder by
splitting the ground to the transponder (at the transponder rack) and
sending one leg to the encoder. Then I would take that ground and
split it into two at the encoder, one hooked to the ground pin and
the other hooked to the strobe pin. Like I said before, most all
transponders want to see the Gray Code (altitude) input at all times,
and the strobe pin being tied to ground means that the encoder will
your avionics guru.
