Michael Valentine
Posted: Sun Jan 22, 2006 8:10 pm Post subject: Rear wing spar question. |
Hello again everyone...
I have just attached my rear spar to the back of the rear ribs and it
is clear that it is not straight. That is, the ribs are not all the
perfect length so the spar is "bowed in" in the middle. I haven't
talked with the factory yet, but has anyone else experienced something
similar and what did you do? It is quite obvious when sighting down
the spar - probably close to a centimeter in the middle - maybe only
half that - tough to tell. (I did check and make sure I had put on
the right spars in the right places - they are all shorter than the
last one so i think I have it right.)
Any help would be appreciated.
Cheers, Michael Valentine
clojan(at)sbcglobal.net Guest
Posted: Mon Jan 23, 2006 8:29 am Post subject: Rear wing spar question. |
michael: I found a use for adding a few aluminum shims in several places durning the build. I believe I used a couple just where you are having the problem . Jack in Los Osos CA
Jack Russell -Clovis CA
601 XL Jabiru 3300
Progress update at:
http://www.geocities.com/clojan(at)sbcglobal.net/zodiacbarn.html
