bobair8(at)msn.com Guest
Posted: Mon Sep 18, 2006 8:41 pm Post subject: BNC "Blindmate" Coax Connector |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I'm installing a Garmin transponder in my "OBAM". The installation calls for the coax (RG-400) to go into a BNC "Blindmate" connector. The instructions call for the exposed braid to be pushed into the connector shell and solder melted in to attach it (in addition to soldering the center conductor on the inside of the connector). This doesn't look like a very mechanically strong connection. Especially since some of the braid bunched up when I pushed it into the connector. I also had trouble getting enough heat on the connector to flow solder without barbequing the connector.
Any suggestions, tips or tricks to get a sound electrical and mechanical connection? How close to the connector do you need to have your first mechanical support for the coax?
Bob
GlaStar
FLYaDIVE(at)aol.com Guest
Posted: Tue Sep 19, 2006 3:22 am Post subject: BNC "Blindmate" Coax Connector |
In a message dated 9/19/2006 12:43:19 AM Eastern Standard Time, bobair8(at)msn.com writes:
| Quote: | I'm installing a Garmin transponder in my "OBAM". The installation calls for the coax (RG-400) to go into a BNC "Blindmate" connector. The instructions call for the exposed braid to be pushed into the connector shell and solder melted in to attach it (in addition to soldering the center conductor on the inside of the connector). This doesn't look like a very mechanically strong connection. Especially since some of the braid bunched up when I pushed it into the connector. I also had trouble getting enough heat on the connector to flow solder without barbequing the connector.
Bob
GlaStar
Here we go again!
Bob:
I am not familiar with 'Blindmate", never heard of it ... Not that it does not exist, just never heard of it. Anyway ...
Just get a good quality SOLDER TYPE - BNC connector from a good electronics store, NOT Radio Shack. It will have the solder type center connector and a rubber type 'O' ring/gasket for the braid. A good set of assembly instructions can be found probably at the store or in the library ... Look for them in the ARRL Handbook or ARRL Antenna Book. You may even find instructions over the Internet.
The screw on back of the BNC connector makes a very good mechanical connection as well as an electrical connection. Make sure the screw on back is the proper size for the coax diameter you are using.
Barry
"Chop'd Liver"
"I would rather be Screwed than crimped."
retasker(at)optonline.net Guest
Posted: Tue Sep 19, 2006 7:12 am Post subject: BNC "Blindmate" Coax Connector |
I don't know what a "Blindmate" connector is, but if it is the same as
or similar to the right angle one used on the back of the SL-70 the
method is basically the same. However, on the SL-70 connector the braid
is slid onto the outside of the connector. Are you sure yours says to
slide it into the connector?
As far as getting enough heat, you will need a good 50-60 watt soldering
iron with a large tip and be patient. I used my Weller temperature
controlled iron and it works fine - just take a bit longer than a normal
solder joint. A larger iron would work better or if you have a
heat-shrink hot air gun, you can preheat the assembly to speed things
up. The RG-400 coax and the connector use only metal and teflon, so
there is little problem with harming either unless you go way overboard
with higher temperature than any reasonable soldering iron.
As far as mechanical strength, this is as strong as you are going to get
if you have a good solder joint.
Dick Tasker
Bob
GlaStar
klehman(at)albedo.net Guest
Posted: Tue Sep 19, 2006 7:38 am Post subject: BNC "Blindmate" Coax Connector |
My old 140 watt Weller solder gun also works fine on these Bob. Those
(or an imported knockoff) are pretty cheap and they heat up quickly
for occasional use.
http://www.lashen.com/vendors/CooperTools/Weller_soldering_guns.asp
Ken L.
Richard Tasker wrote:
<retasker(at)optonline.net>
braid is slid onto the outside of the connector. Are you sure yours
says to slide it into the connector?
soldering iron with a large tip and be patient. I used my Weller
temperature controlled iron and it works fine - just take a bit longer
than a normal solder joint. A larger iron would work better or if you
have a heat-shrink hot air gun, you can preheat the assembly to speed
things up. The RG-400 coax and the connector use only metal and
teflon, so there is little problem with harming either unless you go
way overboard with higher temperature than any reasonable soldering iron.
get if you have a good solder joint.
Dick Tasker
> Bob
> GlaStar
nuckollsr(at)cox.net Guest
Posted: Wed Sep 20, 2006 5:13 am Post subject: BNC "Blindmate" Coax Connector |
The "Blindmate" connectors are a product of Palco Connectors division of
Phoenix
Co of Chicago. You can access the products catalog for these devices at:
http://www.phoenixofchicago.com/palco.htm
It's unfortunate that they didn't craft a series
of these connectors that crimp on like a D-Sub connector.
Nevertheless, as Richard has noted, you're unlikely to injure
these connectors or RG-400 coax with soldering temperatures.
The goal will be to get sufficient heat to the joint to get-on,
get-off with reasonable dispatch which also means there's
sufficient temperature rise to get good solder flow into
the joint.
Here's another link to info on this product:
http://www.bfioptilas.es/Blindmate_Coax-l6049.htm
I don't know what a "Blindmate" connector is, but if it is the same as or
similar to the right angle one used on the back of the SL-70 the method is
basically the same. However, on the SL-70 connector the braid is slid
onto the outside of the connector. Are you sure yours says to slide it
into the connector?
up. The RG-400 coax and the connector use only metal and teflon, so there
is little problem with harming either unless you go way overboard with
Dick Tasker
>flow solder without barbequing the connector. Any suggestions, tips or
>Bob
>GlaStar
-- incoming mail is certified Virus Free.
Checked by AVG Anti-Virus.
< with experiment. >
< --Lawrence M. Krauss >
