wingsdown(at)comcast.net Guest
Posted: Sun Aug 27, 2006 8:49 am Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: 082706
Custom air oil separators as seen on sportflight pic post $150.00
each......................both for 250
CAP 140 complete hub assembly for NSI redrive, may fit others, no blades
$1,500 OBO.............
E.I digital EGT instrument, no probe $180 each or both for
$300.00....................
Hand held radio Yaesu VXA-200. This was there top of the line model and
should be compared to same now, has altitude,density altitude,pressure
alt. Temp, VOR heading plus extra Nmhi battery and programming software
and cable, list was over $600.00 sell for $350.00....................
COM/nav antenna model VHF5-1 by AAE thin flat composite style list $125
sell for $85.00..................
Intercom by PS Engineering model PM1000II with digital cockpit record
option $300.00..................
Electric clock model MD-90 $60.00.....................
Electric servo/ jack screw assembly $500.00 OBO..................
Wheel pant left side only painted ready to mount or repaint
$50.00............
VDO gages:
2 1/8 tack , water temp,oil pressure, boost, large RPM 3 1/8 maybe 1/4,
EGT make offer..............
Cargo bay bag with aluminum custom fit bottom, no sagging. $95.00
........................SOLD
Horizontal Stabilator faired strut braces pair $100.00.................
Custom super trapp exhaust system. Will require the welding of a 3 bolt
flange to exhaust down pipe. $300.00 Pics on request....................
EA-81 turbo engine parts, blocks, engine mounts left and right, cranks,
rods, push rods, heads, cams, open price to be set, accepting
offers................
NSI alternator pulley New $60.00.......................
SS flight controls all factory parts available in excellent
condition....................
Carbon monoxide by coguardian. Plugs into lighter socket audible plus
digital level indicator. They have a web site. $99.00 ...............
Bendix/King fin type transponder antenna with ground plane plate
$50.00.....................
Airborne vacuum regulator valve model 2H3-23 #9AK FAA PMA list $728.00
in ACS catalog make offer..................
Airborne filter mount with filter best offer.............
Wood pistol grips modified one short on passenger PIC side regularl
length with PTTs $50.00 both..................
Mr. Funnel large for water seperation funnel filling of fuel
$20.00...............
Remote PTT $5.00 with other purchse..............
Cessna dual vacuume gage with pop up no vac indicators can be used on
single system PN C668519-0101 $35.00............
Tire or tyre front Aero classic 11X4.00-5 8ply with new tube
$40.00......................
Cockpit light with flood or spot adjustment (model S1990) with red or
white light adjustment, with dim bright adjustment manufactured by
soderberg $55.00.......................
Landing light pulse unit. This is a CODE 3 unit model 700 which will
pulse or run steady, switch able $30.00. Beats the heck out of STC
units...........SOLD
Thanks so much
Rick
Posted: Fri Sep 01, 2006 5:14 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: 090106
sell for $85.00..................SOLD
$50.00............
VDO gages:
SOLD
Thanks so much
Rick
Posted: Tue Sep 05, 2006 4:37 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: 090606
Custom air oil separators (as seen on sportflight pic post) $150.00
$50.00............
VDO gages:
Carbon monoxide by co-guardian. Plugs into lighter socket audible plus
units...........SOLD (no check yet)
Thanks so much
Rick
algate(at)attglobal.net Guest
Posted: Thu Sep 14, 2006 7:01 am Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
I am interested in the faired stabilizer struts if still available. I have
sent a couple of emails to your private address but received no response.
Gary Algate
1 (795) 716 0710
| Quote: | >>>>>>>>>>>>>>>>>>>>>>
Thanks so much
Rick
Posted: Thu Sep 14, 2006 5:26 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Not sure what happened. The email address is wingsdown(at)comcast.net. My
address is:
Rick Chandler
2433 Heavenly Way
Corona Ca 92881
If you send a check just put a note on it what it is for. I would say
add about 20 for shipping and I will refund the unused amount.
Rick
av8rps(at)tznet.com Guest
Posted: Thu Sep 14, 2006 5:28 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Gary;
I can save you some effort, as I've already talked to Rick about those
struts. His airplane is a model V, so the strut is different than the IV
(it has a single strut instead of the two piece "V" the IV uses).
Paul Seehafer
..FOR SALE UPDATE:
Gary Algate
1 (795) 716 0710
Thanks so much
Rick
kirkhull(at)sbcglobal.net Guest
Posted: Thu Sep 14, 2006 5:48 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
DO you have a transponder for sale?
Posted: Thu Sep 14, 2006 6:39 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
It was one of the first items that sold, Garmin GTX330, sorry.
Posted: Fri Sep 15, 2006 4:45 am Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Thanks Paul
Well Rick I guess that answers my question. My new plane has the older style
re stab braces and I want to replace them and this seemed a good option. If
anybody else has some please let me know.
I will also contact John McBean and see what he has to offer
Gary
Posted: Fri Sep 15, 2006 4:46 am Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Rick
Thanks for the response - it appears from Paul's posting that I am out of
luck as you have different braces.
Thanks anyway
Gary Algate
Classic 4 Jab 2200
dave(at)cfisher.com Guest
Posted: Fri Sep 15, 2006 6:35 am Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Gary,
There are a few suppliers that sell plastic extruded fairings.
Check http://www.rans.com/ranshome.htm
and also i think BLue sky or McBean
Dave
Posted: Mon Sep 18, 2006 10:15 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: 091706
$50.00............
VDO gages:
Thanks so much
Rick
