dan(at)rdan.com Guest
Posted: Mon Jan 02, 2006 4:21 pm Post subject: Primer, what's the best ? |
OK, I'm just beginning and I'm ready to prime parts,,
any recommendations, I have the ones Van's mention es in the instructions and was just going to pick one of these ??
or ?
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
DANBERGERONHAM(at)aol.com Guest
Posted: Mon Jan 02, 2006 4:39 pm Post subject: Primer, what's the best ? |
Dan: Re choice of primers. Finally a question I can answer! I went w/ one
of Van's recommendations, the Sherwin Williams Industrial Wash Primer, and am
satisfied w/ it. I work the parts over well w/ Scotch Brite pads, wash them
down w/ MEK, and spray two coats of the primer. It dries quickly, looks ok,
and seems to hold up just fine. I bought a junker spray gun fm Home Depot and
taught myself how to use it. My first attempts at spraying empennage parts
weren't too pretty, but hey, only the bugs are ever going to see it. The wings
were much better, and the fuselage parts look great. Be sure to get yourself a
first class respirator (I have a 3-M), change the filters often, use
chemical resistant gloves, and have plenty of fresh air w/ flow thru ventilation (I
use two box fans) for both the cleaning w/ MEK and the spraying w/ the primer;
MEK and primers will do nasty things to your body.
Good luck & good building,
Dan Bergeron
RV-7A (final riveting the aft fuselage and thinking about an engine)
lifeofreiley2003(at)yahoo Guest
Posted: Mon Jan 02, 2006 4:48 pm Post subject: Primer, what's the best ? |
check the archives... I'm punting this one...
Fiveonepw(at)aol.com Guest
Posted: Mon Jan 02, 2006 6:28 pm Post subject: Primer, what's the best ? |
Hi Dan-
You'll get a BUNCH of feedback on this one! Lot's of opinions on this
subject- here's mine, FWIW:
http://websites.expercraft.com/n51pw/index.php?q=log entry&log id=4863
Welcome to the nuthouse & have fun!
Mark Phillips - Columbia, TN
do not archive since the archives are hard-drive heavy on this subject
already
randy(at)romeolima.com Guest
Posted: Mon Jan 02, 2006 7:14 pm Post subject: Primer, what's the best ? |
or ?
Dan
-8 Tail
Dan, you are asking one of two or three questions that are guarranteed to
spark debate and not likely to find much concensus. Nosewheel vs. tailwheel
is another. All that notwithstanding, here are the materials and technique
I've adopted and used for construction of two RV airframes now...
http://www.romeolima.com/RV3works/Airframe/airframe.htm#Primer
Randy Lervold
www.rv-3.com
www.rv-8.com
