nuckollsr(at)cox.net Guest
Posted: Mon Sep 18, 2006 3:07 am Post subject: radio wires |
At 10:39 PM 9/17/2006 -0500, you wrote:
| Quote: | I must have upset Bob N. with one of my questions of a question. So here
goes again. During the daisy chain from the shields of the mic wires to
the ground wire (all on the radio end of the wires) what is the best way
to tie the pig tail into the ground wire coming from the aircraft ground?
No I m not using a ground wire with a shield. The diagram shows the
shields attaching to the ground wire from the aircraft ground pin. I m
using d-subs.
Why would you think that I'm upset? I have x-hours a day
to devote to various activities. When I open the List postings,
I start at the most recent and work backwards. I almost never
pick up all the slack . . . there's not enough time. However,
if I attempted to pick up where I left off in the postings
and move forward, I'd never catch up. About once a month, I
discard incoming e-mails I didn't have time to address. They
number in the hundreds.
If you'll recall, I wrote a few days ago:
"Okay, got the scans. Great."
"I guess I'm not sure what the question is. The schematic shows
two aircraft ground (A/C Ground) connections to pins 4 and 15.
Wires that the manufacturer recommends be shielded have their
shield grounds returned to specific pins. They also show how
the shield can double as a ground return for mic, headphone,
speaker leads, etc. Further, their wiring suggests exactly
the same daisy-chaining technique I described in:"
http://aeroelectric.com/articles/pigtail/pigtail.html
At some point you wrote:
"I'm wiring the harness for a Terra TX-760D radio. My question is the
interconnect diagram shows the shield for the mic. audio, mic. key and the
headphone attach to the ground. I plan on using the daisy chain system
shown by Bob, however I'm confused about the shields connecting into the
ground wire itself or do they connect to the shield of the ground wire?"
Whereupon I was having trouble developing a
common mental image with you and wrote:
"OOPS! I just re-read your question and I think missed
something the first time. You talk about a "shield of
the ground wire".
Here's where I stumbled over your syntax and
interpreted your words to paint an image of
the ground wire as being shielded also where
I attempted to elaborate . . .
"The drawings show single strands of wire from pins 4 and
15 to ground. Your pigtails would either solder onto the
shared solder cups or splice into the ground wires immediately
adjacent to where they drop into the crimped on pin pocket.
The ground wires are not shielded."
So where are we with respect to achieving understanding?
Your pigtails must make electrical connection with
the single strand ground wires depicted in your drawings.
You have few choices . . . The solder cups and crimp-on
pins won't take two wires. So, you either splice your
pigtails into a ground wire (Strip back 1/4" of insulation
without cutting the wire. Wrap pigtail around ground wire,
solder and cover with heat shrink) or tack solder the
pigtail to the side of the ground wire solder cup.
Understand that few things "upset" me . . . the best
way is to inject yourself between me and one of my
customers by sowing the seeds of discontent and
misunderstanding and preventing me from carrying
out my duties as an honorable supplier of goods
and services. A past poster on the List claims to
have done just that . . . for THAT, there were
no words I could write on these pages to describe
my degree of upset. Aside from overtly dishonorable
behavior, you're not going to yank my chain and
certainly not over a discussion on shield pigtails!
Jim Baker
Posted: Mon Sep 18, 2006 6:10 am Post subject: radio wires |
| Quote: | The solder cups and crimp-on
Well, they will....but it ain't pretty. My Mitchell CIII autopilot
(Bless their little hearts!) had no less than three pairs of doubled
up wires into the back of a Centronics 24 solder cups. When one
of the contact tabs internal to the male connector folded over I
had to replace the Centronics connector and build up a service
loop pigtail to mate it all back together again. So, I'd probably
make this plea.....if you don't ever think that you'll have to
replace a specific connector, you will.
Jim Baker
580.788.2779
Elmore City, OK
Posted: Mon Sep 18, 2006 7:04 am Post subject: radio wires |
At 09:09 AM 9/18/2006 -0500, you wrote:
If it wasn't pretty, then the technology was being
abused. If you need to bring multiple wires into
a connector of either the solder or crimp variety do a
soldered, heat-shrink covered splice of the gaggle of
wires and bring out a single lead to drop into the
connector pin.
The connector manufacturer guarantees stated performance
when the product is use within limits. I've see techs
peel out half the strands of two wires so as to crimp both
conductors into a single pin . . . you're right, it ain't pretty.
Splicing external to the connector pin is the way to go.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
