300 HP engines
BPA(at)bpaengines.com
PostPosted: Mon Sep 18, 2006 5:55 am    Post subject: 300 HP engines Reply with quote
The angle head IO-540 can be ruled out as a candidate for the -10 because of the increase in both width and weight. Additionally, don’t expect 290-300 HP from the standard vertical induction (D4A5-C4B5) sump as the inlet throat is too small requiring the ‘smaller’ RSA-5, AFP FM200, or Precision servo, and the inlet air is heated from the oil temps and is not very efficient, regardless of compression ratio. That being said, an increase in compression of 9:1 will net you an increase of about 6-8, possibly 10 HP without any detrimental effect on the engine. But, increase the compression to say, 9.5:1 and higher, and the bearing load particularly the rod bearings, increase substantially. This will affect the TBO of the engine. In a nut shell the higher the compression, the lower the TBO of the engine. The Cold Air Induction system that some builders are opting for has a three inch opening allowing the use of a bigger fuel servo. An engine configured with Cold Air, RSA-10 or AFP 300 A servo, 9:1 compression can and has dynoed at 290 plus sea level horsepower. The Cold Air Induction won’t fit under the standard Van’s cowl because of the plenum chamber depth and inlet air location, but there is an alternative cowl design in the works (James Cowl).
Not meaning any disrespect to John as I value his knowledge and input and have had several very meaningful conversations with him (thanks John), but there is no significant difference in weight or width between the old narrow deck and current wide deck cases. The narrow deck cases of yesteryear have screw in ½ “ case studs that were anchored in one half of the cases. The newer style wide deck cases have shouldered, or body fit through bolts. Also, the narrow deck cases have a narrower cylinder stud pattern than the wide decks and require plates under the cylinder base nuts for rigidity.
I hope this clarifies just a few questions.
Allen Barrett
BPE, Inc.
www.barrettprecisionengines.com
I've stopped [b]54,091[/b] spam messages. You can too!
One month FREE spam protection at www.cloudmark.com
 Filesize:  1.71 KB
 Viewed:  2337 Time(s)
speckter(at)comcast.net
PostPosted: Mon Sep 18, 2006 12:56 pm    Post subject: 300 HP engines Reply with quote
Just for additional info for inquiring minds, I have one of Allen’s cold air inductions on my engine and am using Van’s standard cowl with some modification.  I am a fiberglass builder of old, Glasair III, and I don’t think that anyone should have any trouble modifying the cowl to make the cold air induction fit.  If you are interested in the specfics of the mod, e-mail me and I will fill you in.
Gary
40274
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of BPA
Sent: Monday, September 18, 2006 9:56 AM
Subject: 300 HP engines
Allen Barrett
BPE, Inc.
 Filesize:  1.71 KB
 Viewed:  2331 Time(s)
KiloPapa
PostPosted: Mon Sep 18, 2006 1:20 pm    Post subject: 300 HP engines Reply with quote
Do you have a photo of the cowling mod?
Kevin
40494
----- Original Message Follows -----
Subject: RE: 300 HP engines
Date: Mon, 18 Sep 2006 16:55:56 -0400
Van’s
anyone
Gary
Kevin
40494
PostPosted: Mon Sep 18, 2006 2:00 pm    Post subject: 300 HP engines Reply with quote
When I get back in town I will take some pix. I haven't completed the
glassing yet but will send what I have.
GAry
PostPosted: Mon Sep 18, 2006 2:14 pm    Post subject: 300 HP engines Reply with quote
I didn't expect such a response. I am presently out of town on business, so
I will describe what I did and then take pix when I get back and get the
stuff complete.
I purchased a Brackett #101 filter assembly from a Cessna 175 and other
aircraft (Spruce). It has sufficient surface area to handle our 260++ Hp.
I made a transitional piece from the servo to the filter by gluing Styrofoam
together to make a solid block that I could carve to the correct shape.
After it is carved and sanded nice and smooth, I glassed it with 4 layers of
glass. After cure I dissolved the foam with lacquer thinner, cleaned up the
inside and cut an alternate air door in the top.
I then cut away the interfering part of Van's cowl to allow me to put the
lower cowl on the airframe. I then hot glued foam on the left, right and
bottom side of the filter outside the present inlet scoop on Vans. I plan
on making a larger exit to handle the high cyl head temps that some have
seen. When I left town I had just glued the foam in place and when I get
back I will carve nice curves on it and glass it in place on the outside.
Then I will remove excess foam on the inside and glass it in place.
Sorry if this sounds confusing. I will take pix and post them when I get
back.
Gary
KiloPapa
PostPosted: Mon Sep 18, 2006 3:17 pm    Post subject: 300 HP engines Reply with quote
Thanks, I am looking forward to seeing what you have done.
Kevin
40494
<speckter(at)comcast.net>
town on business, so I will describe what I did and then
take pix when I get back and get the stuff complete.
Kevin
40494
neilcolliver(at)maxnet.co
PostPosted: Mon Sep 18, 2006 4:26 pm    Post subject: 300 HP engines Reply with quote
Hi gary
I have ordered the cold air from Barretts, and so am very interested -
please send pics & details of what you did.
Neil
Gary
40274
Allen Barrett
BPE, Inc.
I've stopped 54,091 spam messages. You can too!
<unknown.gif>
