planecrazzzy Guest
Posted: Sun Jan 22, 2006 2:58 pm Post subject: Shoulder straps too loose |
Hey Guys,
I've seen this "cure" before.....This is MY version ....
I took some elec wire, Red to match my plane...and I macreme'd the shoulder strap.....I need to leave them loose when I fly , so I can lean forward and reach the ignition ( Cessna too , but for "BOTH" fuel )
Anyway, I had a little trouble with the straps sliding off ......not now.
Gotta Fly...
Mike in MN N381PM
60.83 KB |
629 Time(s) |
59.2 KB |
624 Time(s) |
60.4 KB |
642 Time(s) |
JetPilot
Posted: Sun Jan 22, 2006 3:36 pm Post subject: Re: Shoulder straps too loose |
Hi Mike,
Either that is the worlds biggest shop fan, or you are flying a powered parachute, or trike. Do you still fly that thing, or do you like the firestar so much that it just sits ? Lets see more pictures of your entire plane, the red checkerboard looks pretty cool.
Michael A. Bigelow
Kolb MK-III Xtra, 912-S |
planecrazzzy Guest
Posted: Sun Jan 22, 2006 3:54 pm Post subject: Re: plane pictures |
He's some Pic's.... Ralph took these pictures the day of my First Flight...
Oh, the"FAN" is a Buckeye Powered Parachute,Dream Machine,2 seat
582/ 3 blade IVO , For Sale - $8,000
Gotta Fly...
Mike in MN
129.88 KB |
659 Time(s) |
122.22 KB |
620 Time(s) |
123.47 KB |
620 Time(s) |
JetPilot
Posted: Sun Jan 22, 2006 5:58 pm Post subject: Re: Shoulder straps too loose |
Nice looking plane Mike. The professional lettering on the panel is a nice touch, how did you do that ?
What is that guage called the miZer ???
planecrazzzy Guest
Posted: Mon Jan 23, 2006 3:29 pm Post subject: Re: Shoulder straps too loose |
Hi,
The "lettering" on the dash is done with my computer, then "taped" in place..... One is my "N" number.... on the other side are my "V speeds"
And I put "Stall" and "VNE" in RED
I also labeled all the other stuff that way for my airworthiness inspection.
I used the WIDE clear tape, so it seals it , and looks better...
The Gauge that sez " miZer " is my Fuel gauge/fuel flow gauge, and it has an alarm ( at whatever gals "left" I program )
It was a litte SPENDY at $300 bucks from A.S.&S.
Gotta Fly...
| Quote: | The professional lettering on the panel is a nice touch, how did you do that ?
