Wing to Fuselage Electrical Connector
tonyk(at)kaon.co.nz
PostPosted: Sun Jan 22, 2006 8:19 pm    Post subject: Wing to Fuselage Electrical Connector Reply with quote
> Would like to get a consensus of what type of electrical connector
everyone has used between the wings and fuselage. What I have is in
need of replacement.
I've used AMP Universal 15A Mate-n-Lok connectors for my wing
connectors. Whichever connector you use ensure that you have the proper
crimping tool to ensure a solid connection. In my case I used an AMP
ratchet crimper with the appropriate crimp head.
You can also get a really good faston type connector multi block,
Positive Lock 250 Series, for up to 8 wires from AMP . Once these
connections are made it takes a very deliberate action to separate them
and I've used them for my mag and master wires from the panel. If you
already have a faston type crimper then you might want to to consider
these.
Tony
