Heat exchanger for the XS Europa
Goto page Previous  1, 2
grahamsingleton(at)btinte
PostPosted: Fri Sep 15, 2006 11:00 am    Post subject: Heat exchanger for the XS Europa Reply with quote
Richard
The CAA is mainly interested in avoiding any possibility of being blamed
themselves. That's why they are so reluctant to be positive about so
many things
Graham
Richard Holder wrote:
In the Land of the Free you are free to risk whatever you
like as YOU have to sit in it. The CAA would like anyone
who sits in the plane to be guaranteed safety Smile Ha ha !
Richard
G-OWWW
High Cross
Gilles.Thesee(at)ac-greno
PostPosted: Fri Sep 15, 2006 11:04 am    Post subject: Heat exchanger for the XS Europa Reply with quote
Graham,
the duct needs to be properly designed for efficient, low drag cooling
too.
I sure do agree.
You'll find some details on how I designed our radiator duct :
http://contrails.free.fr/tunnel_en.php
No cooling air leaks whatsoever. In flight we can adjust the temps
within 5 °C of the target temperature we choose.
Having an efficient inlet diffuser gives us plenty of high pressure 70°C
air behind the radiators.
Several XS builders did redesign the duct with noteworthy results. Bob
Berube might enlighten us if he's still listening?
Graham
Best regards,
Gilles
mikenjulie.parkin(at)btop
PostPosted: Fri Sep 15, 2006 11:27 am    Post subject: Heat exchanger for the XS Europa Reply with quote
Not entirely true. G-JULZ has a cockpit heater based on the hot air behind
the radiators being ducted, via bulkhead shutoff valves, into the cockpit.
All PFA approved.
regards,
Mike
karelvranken(at)hotmail.c
PostPosted: Fri Sep 15, 2006 11:28 am    Post subject: Heat exchanger for the XS Europa Reply with quote
Nigel,
Every builder, I think, is interested in cabin heating if....if. Technicaly it has to be simple. Practicaly easy to execute and without sacrificing other good arrangements. Not to much added weight. Easy in usage and comfort, and last but not least, not to expensif.
Before placing an order I would like to have more information.
Karel Vranken.
# 447 F-PKRL XS mono 912ULS Airmaster 332 passed last control and waiting for "Laisser passer" for first flight in Sedan.
peter.rees01(at)tiscali.c
PostPosted: Fri Sep 15, 2006 12:02 pm    Post subject: Heat exchanger for the XS Europa Reply with quote
G-MFHI already has a cabin heat - is this standard in the classic? It consistes of a fibreglass moulding over the stbd rad which ducts air into a section of scat hose which (via a rather tortuous route) feeds into a section of the exhaust - this then feeds out via scat hose and a shut off valve to the P1 footwell.
The heat exchanger muff certainly looks to be part of the original exhaust.
Peter
ptag.dev(at)tiscali.co.uk
PostPosted: Fri Sep 15, 2006 12:31 pm    Post subject: Heat exchanger for the XS Europa Reply with quote
Hi! Nigel
Never had a problem with cabin heat with my Jabiru 3300 hot air from oil cooler manifold.
However now I’ve Insurance settlement and changing to a 914 Rotax I guess you’d better register my interest , please,! (Assuming I have any money left over !) Presuming it will be effective for a 914 ? However may I suggest it is a heat collector manifold catching heat from the coolant system or oil cooler system, can’t abide by any thought of Carbon Monoxide poisoning it would be as bad as freezing to death !
Bob Harrison G-PTAG ( due in the air as soon as an engine is available like quoted 6-9 months !)
Robt.C.Harrison
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of nigel charles
Sent: 15 September 2006 10:21
Subject: Heat exchanger for the XS Europa
The manufacturer for the Europa exhaust has shown interest in producing a heat exchanger box to be fitted to the XS version of the aircraft. Before they move forward and design the product they want to find out how much of a market there is for such a device. Obviously it is only worth their while if enough owners would buy one. Any one who is interested should email me so I can give the manufacturer an idea of the numbers involved.
Nigel Charles [quote]   - The Europa-List Email Forum - -->   - NEW MATRONICS WEB FORUMS - -->   - NEW MATRONICS LIST WIKI - -->   - List Contribution Web Site - Thank you for your generous support!     -Matt Dralle, List Admin. --> [b]
robh(at)hyperion-ef.us
PostPosted: Fri Sep 15, 2006 1:18 pm    Post subject: Heat exchanger for the XS Europa Reply with quote
While my scheme is not literally using air from outside of the cowling, the
duct created by CD1, CD2, CD3, and the rubber seals against the fiberglass
cowling isolates the cooling air flow from everything else within the
cowling. More importantly, and not apparent unless you see the actual
design, there is a stainless steel "fire door" that will shut off the air
flow to the cockpit (at the firewall) if there is a fire within the
cowling - the "fire door" closes automatically because it is spring loaded
and held open by a fusible link that will melt at 100 deg C.
Unfortunately I can't overcome the objection to a burst heat exchanger
allowing hot liquid into the cabin air stream. However, the way that I have
designed the intake to the SCAT tube would minimize ingestion of liquids
into the cabin air, and unless the occupants were incapacitated it would be
easy enough to shut off the flow of heated air.
I've attached the details of my scheme to another message posted with this
one.
Best regards,
Rob Housman
A070
Airframe complete
Irvine, CA
PostPosted: Fri Sep 15, 2006 1:47 pm    Post subject: Heat exchanger for the XS Europa Reply with quote
My first attempt to post the details as an attachment got bounced because
the attachment (at 1725 Kb) is too large (1000 Kb max. allowed). I have
submitted it to Matt for inclusion in the file and photo sharing at
Best regards,
Rob Housman
A070
Airframe complete
Irvine, CA
sidsel.svein(at)oslo.onli
PostPosted: Fri Sep 15, 2006 10:24 pm    Post subject: Heat exchanger for the XS Europa Reply with quote
Nigel,
Great - yes, please.
Bets regards,
Svein
LN-SKJ
ami(at)mcfadyean.freeserv
PostPosted: Sat Sep 16, 2006 1:25 am    Post subject: Heat exchanger for the XS Europa Reply with quote
Another way is to route fresh cold air from the front of the cowl back to the firewall/cockpit using the very lightweight corrugated aluminium vent tube used on automotives. This picks up heat (by exchange process) as it passes through the hot (c.60C) cowl space. May not work in extremes of climate?
Duncan McF.
g-iani(at)ntlworld.com
PostPosted: Sat Sep 16, 2006 1:58 am    Post subject: Heat exchanger for the XS Europa Reply with quote
I have just reviewed the correspondence on cabin heat and following a
conversation with Andy Draper this week a few points seem worth making.
I also have the cooling duct off my aircraft at present and thought it
was a good idea to do something like this while I had it in bits.
I had a long talk with Andy Draper this week (now with the PFA). He has
been given the job of sorting out the mess of Standard Mod applications
that has built up due to the staff leaving the PFA. This is very good
news for us UK flyer/builders. With Andy's help I hope we can progress
the standard mods that have been sitting with the PFA for just on a
year. I, with Andy's help, will also look at other mods that should
become standard (or even Factory as with the tri gear springs) and a
standard mod for cabin heat seems a very good idea. As part of this we
will ensure that the mods are accessible, to all, via the PFA web site.
This was supposed to have been done month ago but again a PFA problem.
The 914 exhaust is a Rotax part so is not going to be involved in any
work CKT do with the 912 system they produce.
The idea of a heat exchanger off the exhaust strikes my as "spam can"
technology with the risks of CO and incoming air at temperatures far
higher than you really need.
(by the way Alan, an intercooler is used to reduce the temperature of
the incoming "charge" air not to keep engine temps down.)
The XS has a very suitable source of nicely warm (70 deg C) air behind
the water/oil radiators (Sorry Classic owners but this did start as an
XS topic)
As Rob Housman has said "What the Europa factory forgot was the
necessary ducting to get warmed air into the cockpit". Thanks for
posting the details via Matronics. It is not up as of now (Sat 10.00Z)
but I look forward to seeing them.
In particular the stainless steel "fire door" that will shut off the air
cowling (fusible link) seems like a very good feature. Yes to totally
eliminate the burst heat exchanger allowing hot liquid into the cabin
air stream is difficult. However the design of the intake to the SCAT
tube (and a vertical section of the SCAT tube) should minimize ingestion
of liquids into the cabin air. If you have some sort of air box in the
top of the foot well this could also be designed as a liquid trap.
Mike Parkin has pointed out "G-JULZ has a cockpit heater based on the
hot air behind the radiators being ducted, via bulkhead shutoff valves,
into the cockpit. All PFA approved". Mike could you please let me have
details of the mod or at least the Mod number so I can get it from the
PFA.
I have Paul McAllister's picture of his take off from the duct but a few
more details of the flap hinge duct etc would be greatly appreciated.
Gilles your details on the cooling duct research are great but do you
have any details on the ducting?
Does anyone else have a solution to this problem? All ideas are
welcome.
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
kheindl(at)msn.com
PostPosted: Sat Sep 16, 2006 4:19 am    Post subject: Heat exchanger for the XS Europa Reply with quote
Yes, Duncan and Ian, there is an idea I had for a long time but haven't had
a chance to try it out. It is extremely simple but would only be of interest
to those of you who have that ducting shroud over the top of their engine.
The temperature under that shroud is 32C degrees above oat.
All you need is : two aluminum flanges, one eyeball vent, four nuts and
bolts four rivets, and a piece of scat tube.
One flange is riveted on top of the port side of the shroud , first making
a hole in it of course, the second goes on top of the footwell next to the
vertical firewall, and is bolted together with the eyeball vent on the
inside. The vent is difficult to reach once you are strapped in, but is good
enough for me.
Tha vast majority of builders don't need extreme heat, and I can't afford to
fly in the middle of winter (hangar space needed etc.) , but there is a need
for cabin heat on cold days and at altitude.
I don't think the PFA would have a problem with that mod. It is all clean
fresh air and no liquids.
Karl
[quote]From: "Duncan & Ami McFadyean" <ami(at)mcfadyean.freeserve.co.uk>
Reply-To: europa-list(at)matronics.com
To: <europa-list(at)matronics.com>
Subject: Re: Heat exchanger for the XS Europa
Date: Sat, 16 Sep 2006 10:25:02 +0100
climate?
Duncan McF.
donaldheath(at)sbcglobal.
PostPosted: Sat Sep 16, 2006 7:36 am    Post subject: Heat exchanger for the XS Europa Reply with quote
nigel charles wrote:
<![endif]--> Clean Clean DocumentEmail MicrosoftInternetExplorer4 <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} <![endif]-->
Nigel Charles
I am interested in heat exchanger you mention.
Don Heath
1015 Eddy Lane
Eau Claire, Wi. 54703 USA
air.guerner(at)wanadoo.fr
PostPosted: Sat Sep 16, 2006 11:25 am    Post subject: Heat exchanger for the XS Europa Reply with quote
Nigel,
I am very interested
Remi Guerner
a heat exchanger box to be fitted to the XS version [quote][b]
Page 2 of 2
