Dennis Jones
Joined: 17 Sep 2006 Posts: 45 Location: Poplar Grove, IL
Posted: Wed Sep 20, 2006 7:53 am Post subject: Switched power |
For the encoder I plan on using a seperate fuse to the POWER IN pin (8)supplied from the a/c power to reduce warm up time and then use pin (14) SWITCHED POWER IN as indicated by the schematic for the switched power back to the transponder. Now for the question. The transponder schematic shows two pins together (8,20) used for SWITCHED POWER OUT. Do both of these get wired to the switched pin number 14 or because I'm powering the encoder pin 8 with its own power is one of these pins left empty?
