coop85(at)bellsouth.net Guest
Posted: Thu Sep 14, 2006 4:36 pm Post subject: Magneto question |
Since you haven’t played with the mixture yet, you may want to do a good run-up and lean the heck out of it. Then check it again. However, this usually works only if the plugs are fouled and it sounds like yours are not if the plugs look good.
Marcus
From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of Bert Murillo
Sent: Thursday, September 14, 2006 6:37 PM
To: rvsoutheast-list(at)matronics.com
Subject: Magento question
HI:
I have found that when doing the mags check, there is a difference of more than
150 rpms between the mags, as recommended by lycoming..
Timing is OK, plusgs are ok, only one not checked is mixture, but i do not think
this has anything to do with it...
Any suggestions, appreciated. Engine is a Lyc. 0320e2d 150 HP
bert
rv6a
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
