kearney(at)shaw.ca Guest
Posted: Mon Sep 11, 2006 2:58 pm Post subject: Compressor Recommendation - Redux |
Hi
Here I was already to get a Husk compressor when I can across an oil free
Porter Cable compressor with the following specs:
Noise 82dba
Tank 26 gal
Max Pressure 175 psi
Two stage, direct drive, twin cylinder
3 year warranty
1.6 running HP motor
Model CPFC2TV3525VP
This is also a bit cheaper than the Husky VT6315.
Does anyone have experience with Porter Cable products (and perhaps this
model in particular)?
Cheers
Les
RV10 Wannabe
n8vim(at)arrl.net Guest
Posted: Mon Sep 11, 2006 3:45 pm Post subject: Compressor Recommendation - Redux |
Oil less?
Run away! Run away!
It is pretty loud to boot!
-Jim
Les Kearney wrote:
Hi
Noise 82dba
Tank 26 gal
3 year warranty
Model CPFC2TV3525VP
Cheers
Les
RV10 Wannabe
Tim(at)MyRV10.com Guest
Porter cable generally makes good stuff, but I'd recommend
avoiding an oil free compressor. You'll likely be happier
with an oiled model, especially with cast iron cylinders,
as they're quieter, and will probably last much longer too.
You also don't need anything over 110-125 psi for the plane build.
Les Kearney wrote:
Hi
Noise 82dba
Tank 26 gal
3 year warranty
Model CPFC2TV3525VP
Cheers
Les
RV10 Wannabe
jwt(at)roadmapscoaching.c Guest
Posted: Mon Sep 11, 2006 4:04 pm Post subject: Compressor Recommendation - Redux |
That Husky is a great unit - I'd go for that one.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Finish kit - wheel fairings, cowl prep
pascalreid(at)verizon.net Guest
Posted: Mon Sep 11, 2006 4:14 pm Post subject: Compressor Recommendation - Redux |
same as the Craftsman #00916778000.
Which received the following review
Product Reviews
Overall Rating: 5 5
August 8, 2006
By toolman from Massachusetts
Reliability: 5 5
Value: 5 5
Performance: 5 5
Durability: 5 5
"It's the absolute best tool i've ever bought in my life.
It run all the air tools."
1.2 KB |
4042 Time(s) |
79 Bytes |
4045 Time(s) |
Posted: Mon Sep 11, 2006 4:23 pm Post subject: Compressor Recommendation - Redux |
If you absolutely need a vertical than you'll do fine with this but for the
same money, if space allows, I would encourage another Porter-cable- but in
the Craftsman quise the #00919541000,
SCFM Delivery At 40 psi 8.6 SCFM
SCFM Delivery At 90 psi 6.8 SCFM
compared to your choice
SCFM Delivery At 40 psi 5.6 SCFM
SCFM Delivery At 90 psi 5.1 SCFM
same price but the best CFM I have found. Just something to consider.
Pascal
dlm46007(at)cox.net Guest
Posted: Mon Sep 11, 2006 4:35 pm Post subject: Compressor Recommendation - Redux |
Is anybody building an aircraft? The last 50+ emails have been the same
compressor subject.
Rick S.
Rick S.
Posted: Mon Sep 11, 2006 5:37 pm Post subject: Compressor Recommendation - Redux |
It's obvious that all the problems in the construction of the RV-10 have been solved. Any of you newbies want to ask about shimming up the nose ribs on the VS & HS or SOMETHING besides hot, compressed air.
Hey....What kinda primer youse guys and gals using?
Rick S.
40185
click click...thats my relays a working!!!
_________________ Rick S.
RV-10
40185 |
rvbuilder(at)sausen.net Guest
Posted: Mon Sep 11, 2006 6:50 pm Post subject: Compressor Recommendation - Redux |
I would be surprised if you get an oiless hat makes it through the
entire project. They have a bad tendency to burn up after a few hundred
hours. And 82db is quite loud, like ear plug loud if it's in the same
room being used regularly.
Michael Sausen
-10 #352 Fuselage
