hgmckay
Posted: Tue Sep 12, 2006 1:02 pm Post subject: New 912 Engine Starting Problem |
Gentlemen:
<![if !supportEmptyParas]> <![endif]>
After running my new Rotax 912UL in my Allegro 2000 for four successful trial runs, I decided to drain the main tank and refill it with new fuel. I drained the tank completely through the low point drain and refilled the tank about half full. When I tried to re-start the engine, it would not hit. It just turns over and over. Ignition is on, choke is on, and I am operating the electric fuel pump during the start sequence. I have tried three times to start the engine with the same result. I have done nothing different from the initial four runs other than draining the tank and refilling. Could I have a vapor lock or trapped air somewhere? I would think that the electric fuel pump would take care of air or a vapor lock in the lines between the pump and the carbs. Fuel bowls have stayed dry. Any suggestions how to find the problem, and correct it?
Hugh McKay
Allegro 2000
N661WW
thilo.kind(at)gmx.net Guest
Posted: Tue Sep 12, 2006 1:18 pm Post subject: New 912 Engine Starting Problem |
Hi Hugh,
suggest to check the fuel lines to the carburetors with the electrical fuerl pumps running. Could be, that you are sucking fuel from the tanks to the electrical fuel pump. With the tank now half full (less pressure) you might create vapour lock in the suction line from tank to electrical pump.
Good luck
Thilo
lostpilot28
Joined: 26 Jul 2006 Posts: 7 Location: Southern California
Posted: Tue Sep 12, 2006 1:34 pm Post subject: New 912 Engine Starting Problem |
Hi Hugh,
I typically run my electric fuel pump until my 2 psi fuel pressure light goes out plus about 5 seconds. This puts fuel in the float bowls and pressurizes the fuel lines. I've never had a starting problem. My guess is that you not only drained fuel from the tanks, but the lines as well (gravity fed back to the tanks).
Sonny W.
jkuehn(at)mountaintime.my Guest
Posted: Tue Sep 12, 2006 2:37 pm Post subject: New 912 Engine Starting Problem |
Try disconnecting the fuel lines at the carburetors, one at a time, and
turning on the electric pump briefly to clear the line. Make sure fuel
is flowing. I have had slow starting after draining things out, and I
do not think you have a real problem here, just no fuel getting to the
engine.
Jack
Hugh McKay III wrote:
| Quote: | Gentlemen:
Hugh McKay
Allegro 2000
N661WW
Thom Riddle
Posted: Wed Sep 13, 2006 4:28 am Post subject: New 912 Engine Starting Problem |
Hugh,
1) Is the fuel tank valve turned on? I know this is obvious but
sometimes we forget. I have
2) Are both mags on? I've forgotten this one too.
3) Does the fuel pressure gauge read in normal range with just the
electric boost pump on? It should with just the master on and the fuel
pump switch/cb on, and not cranking.
4) When you crank, does the fuel pressure change? With the engine
mechanical pump also doing its job, the fuel pressure reading should be
a little higher than with just the electric pump on.
If 3 & 4 are good, then you know you are getting fuel to the engine,
and the carbs, if there is no leak in the fuel system in the engine
compartment, which would be visually obvious with the upper cowl off.
This also means you are not getting vapor lock anywhere.
If the engine is cold, make sure that the choke is full on and the
throttle is completely closed. When cold the engine will not start if
the throttle is open even a little.
If it still won't start, remove the drip tray under one carb and then
the float bowl to see if the bowl has fuel at the proper level and the
float valve moves up and down okay. While you have the float bowl off,
check to see if the starting circuit jet is loose. The starting jet is
in the bottom of the little vertical cylindrical area in one corner of
the bowl. If it is loose it could affect starting mixture and if it
does start cause rough idling. Do this same thing for the other carb.
and then reassemble carefully making sure you get the bowl gaskets
seated properly.
If after trying all of this it does not crank, let us know and we'll
proceed from there.
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
