Compressor Recommendation
kearney(at)shaw.ca
PostPosted: Sun Sep 10, 2006 8:52 am    Post subject: Compressor Recommendation Reply with quote
Hi
I am starting to set up an area in my garage that I can use as a workshop. The only power I have in the garage is a single 15 amp circuit. This powers a fridge, a freezer as well as lights, power receptacles and the garage door opener.
I have a single breaker slot open on my power panel and plan to run an additional circuit. Assuming I run all my intermittent use tools (band saw / drill press) off the new circuit, will the new 15 AMP 110V circuit be sufficient for a compressor as well. If so can anyone recommend an appropriate compressor given that I will not be painting? I have read about the Husky VT6315 from Home Depot on the list, but am wondering if this is overkill for my needs. I have also read that some 15 amp compressors can cause breaker trips.
Any guidance most welcome.
Les
RV10 wannabe
n8vim(at)arrl.net
PostPosted: Sun Sep 10, 2006 9:21 am    Post subject: Compressor Recommendation Reply with quote
Les,
A single 15A circuit will handle a good compressor. I have a single
15A circuit for the compressor I have, which I bought 10 years ago; Its
a 20 Gal. "5 HP" Coleman Black Max oil lubed, belt driven compressor
which then cost me about $500; Prices are very similar today.
I put "5HP" in quotes since its not really 5HP.. The marketing folks did
their spin on it. The 5HP is really the power produced at the moment of
the motor stalling. If it were really 5HP... Lets see: 5HP = 3,728
Watts divided by 115v equals 32.4 AMPS !!!
As for breaker trips, most can be avoided by not using undersized wire
from your breaker panel, and also not using any extension cord.
Watch out for similar "marketing" information when looking for a compressor.
-Jim 40384
Les Kearney wrote:
Hi
recommend an appropriate compressor given that I _will not_ be
Les
RV10 wannabe
jdalton77(at)comcast.net
PostPosted: Sun Sep 10, 2006 9:44 am    Post subject: Compressor Recommendation Reply with quote
I bought one from Harbor Freight for $149 that is a 21 Gallon upright with
3HP motor. It's pretty quiet and has worked for me for the past 9 months.
It handles riveting tasks with no problem. If I'm drilling a lot of think
aluminum (like the longerons) it does kick on quite a bit, but it keeps up.
The die grinder slows down some if I'm using a lot. That said, like
everything from Harbor Freight,it's not the greatest quality but it works
just fine (I do love my pop rivet puller from them though).
I thought about investing in a higher quality compressor since I was going
to use it all the time, but I chose to put my money into a great Sioux
drill, two ATS Rivet guns, and Main Squeeze rivet squeezer from Cleveland..
jjessen
PostPosted: Sun Sep 10, 2006 10:27 am    Post subject: Compressor Recommendation Reply with quote
Les, 15A is fine for most home 2-stage oiled compressors, but I'm not sure you want it on with everything else. I used to have mine on with the shop lights and they didn't like it when it'd come on. I finally found an outlet that had less constant usage and everybody was happy. I bet if your fridge and freezer started their compressors about the same time your compressor kicked in you'd be heading for the panel. But how often would that be? Might be something to live with.
I got a CH one on sale at Sears (floor model). Similar to this guy. I think I got it at $100 off, so it was to good a deal to pass up. I've been very happy with it.
[img]cid:244281818(at)10092006-217B[/img]
On their web site at: http://www.campbellhausfeld.net/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10051&productId=60827&langId=-1&parent_category_rn=10537
John Jessen
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Sunday, September 10, 2006 9:49 AM
Subject: Compressor Recommendation
Hi
Les
RV10 wannabe
s.com/Navigator?RV10-List
 Filesize:  3.24 KB
 Viewed:  5793 Time(s)
pitts_pilot(at)bellsouth.
PostPosted: Sun Sep 10, 2006 10:32 am    Post subject: Compressor Recommendation Reply with quote
If it were me, I'd put in a 20A breaker and run 12 Ga. wire. The cost difference is pennies since you're going to add the circuit anyway. Remember what you're protecting: the wire. There are a couple of reasons that the 15A breakers kick ..... they're operating on the edge of their capability and may also have smaller wire in the circuit. My recommendations would be to get a 220 compressor, 10Ga. wire, and piggyback that on the smallest 220 breaker you have. A good size tank is preferable too. I don't know offhand what size my tank is, but it is a 6 HP upright tank model from Home Depot and cost me $300. Probably a little highter now Sad . If you get a bigger compressor, then you'll never get caught short down the road when you need the air. I wish I had pictures of the two guys locally that manifolded two little 1 HP compressors together to get enough air!!!
Linn
Les Kearney wrote:
Hi
Les
RV10 wannabe
jim(at)CombsFive.Com
PostPosted: Sun Sep 10, 2006 11:38 am    Post subject: Compressor Recommendation Reply with quote
Les,
I have a 1/2 hp belt driven compressor on a 10 gallon tank that has served me very well. I have air plumbed to both a basement workshop (Wings / Emp) and to the garage (Fuselage). It's rated at 1 CFM (at) 100 PSI. It won't paint, but runs 3/8 rachet with no problems at all. The 1/2 inch impact is a bit of a stretch for it. I even put a muffler on the air intake to make it really quiet.
The rivet gun (2x) and air nailers don't tax it at all.
Other tools include a 1 in belt sander (Bench top mounted on a pedistal), 6" grinder with a scotchbrite wheel and a 12" table top band saw. It's unlikely you will be using more than one at a time (Unless you have lots of help).
Just a data point for consideration.
Jim Combs
N312F
40192
Date: 2006/09/10 Sun PM 12:49:10 EDT
Hi
opener.
Les
RV10 wannabe
Tim(at)MyRV10.com
PostPosted: Sun Sep 10, 2006 1:24 pm    Post subject: Compressor Recommendation Reply with quote
Jim,
Please don't take this wrong, but...are you being serious?
I can't tell if you're joking and being facetious, or if
you really are using a 1/2 hp on a 10 gallon tank. I can't
for the life of me imagine using that if you are using
it for an air drill doing countersinking, or using a die
grinder. But, you mention ratchet and impact wrenches....
and those I'm sure would work fine for quick jobs.
jim(at)CombsFive.Com wrote:
Les,
Jim Combs N312F 40192
============================================================ From:
Les Kearney <kearney(at)shaw.ca> Date: 2006/09/10 Sun PM 12:49:10 EDT
To: rv10-list(at)matronics.com Subject: Compressor
Recommendation
Hi
Les
RV10 wannabe
Rick S.
PostPosted: Sun Sep 10, 2006 1:41 pm    Post subject: Compressor Recommendation Reply with quote
LOLOLOL....compressor wars!!!
I have a 5hp/ 26 gal oilless Coleman from Costco, loud as crap, works great except for massive drilling and die grinding. If I had to do it all over I would get a 220 powered two cylinder oiled model with a big upright tank that would be heading into the hangar when I'm done, now my Coleman will stay in the garage for tires and I'll buy a nice quiet one for the hangar for me and me mates.
Rick S.
40185
Rick S.
RV-10
40185
deej(at)deej.net
PostPosted: Sun Sep 10, 2006 2:02 pm    Post subject: Compressor Recommendation Reply with quote
Hi Les,
FWIW this is the unit I am using. I am running it off a single 15A
circuit with no troubles. I can run a few other small items off the
same circuit at the same time, but nothing much bigger without nuisance
trips. The compressor itself has been great running drills, cut-off
tool, etc. It is also fairly quiet, as compressors go. I'm working in
an attached garage, and with the door closed you can hardly hear the
compressor in the house. I highly recommend it.
-Dj
AV8ORJWC
PostPosted: Sun Sep 10, 2006 2:37 pm    Post subject: Compressor Recommendation Reply with quote
Good used secondary storage tanks help in smoothing the demand on the
compressor. Unless you are rotary sanding composite structures for long
periods of time, the smaller residential compressor can fill both the
primary and a backup secondary tank quite well. Remember to have
adequate, multiple filters in the system to remove condensate.
John Cox
PostPosted: Sun Sep 10, 2006 3:27 pm    Post subject: Compressor Recommendation Reply with quote
Tim,
I am serious, It has worked for me so far. I will confess to not using an air drill or air die grinder. I used an electric drill and die grinder. Those will use substantially more air. My drill is not the normal slow turning electric drill. I have always kept extra new bits and if I detect any dull bits, I grab a new one. I have always deburred the holes and they seem to come out fine. My tech couselor has been checking my work and he has not pointed me to the air drill.
I know that runs against the grain for a lot of folks. Air drill vs electric is almost like the engine and primer wars.
Based on the other responses for Les, I think putting in the 20 amp breaker, using the larger wire, and going air tools all the way is the best answer. My compressor has served me well for it being as small as it is. And it's really quiet.
Jim C
Date: 2006/09/10 Sun PM 05:23:38 EDT
Subject: Re: Compressor Recommendation
Jim,
Les,
Recommendation
Hi
Les
RV10 wannabe
kearney(at)shaw.ca
PostPosted: Sun Sep 10, 2006 7:36 pm    Post subject: Compressor Recommendation Reply with quote
Hi Everyone
Many thanks for all the informative replies. Based on my review of the
archives and the comments received, I will go with the Husky.
Cheers
Les
RV10 Wannabe
jwik(at)crary.com
PostPosted: Mon Sep 11, 2006 5:07 am    Post subject: Compressor Recommendation Reply with quote
Mine is mounted to the back side of the wall (hanger and shop are partitioned) feeding a hose reel on the wall in the shop. Keeps the compressor from getting in the way and eliminates the annoyance when the compressor kicks in. The reel keeps hose out of the way when not using air.
linn Walters wrote: [quote] If it were me, I'd put in a 20A breaker and run 12 Ga. wire. The cost difference is pennies since you're going to add the circuit anyway. Remember what you're protecting: the wire. There are a couple of reasons that the 15A breakers kick ..... they're operating on the edge of their capability and may also have smaller wire in the circuit. My recommendations would be to get a 220 compressor, 10Ga. wire, and piggyback that on the smallest 220 breaker you have. A good size tank is preferable too. I don't know offhand what size my tank is, but it is a 6 HP upright tank model from Home Depot and cost me $300. Probably a little highter now Sad . If you get a bigger compressor, then you'll never get caught short down the road when you need the air. I wish I had pictures of the two guys locally that manifolded two little 1 HP compressors together to get enough air!!!
Linn
Les Kearney wrote:
Hi
Les
RV10 wannabe
pascalreid(at)verizon.net
PostPosted: Mon Sep 11, 2006 8:39 am    Post subject: Compressor Recommendation Reply with quote
interestly Homedepot has the VT6315 as 5 HP as well, it's interesting
because the CH VT6315 in the Campbell Hausfeld website states "2HP" for the
compressor, they are the same compressor, I guess putting the "Husky" label
on the compressor gives it a 3HP boost!
Tim(at)MyRV10.com
PostPosted: Mon Sep 11, 2006 9:55 am    Post subject: Compressor Recommendation Reply with quote
Actually, I know EXACTLY why the same pump is listed at 2 different
HP's. When I got my VT6271 (I think that was the number), it wasn't
long after and I got notifications of a class-action lawsuit.
Eventually, if you had a compressor labeled with the higher HP
rating from certain years, you were entitled to file a claim and
get something like $50 of free product from CH. It seems someone
got tired of misrepresentation of HP ratings on compressors,
and the lawsuit got going. Mine was labeled properly, but I'm
sure this is why CH is listed lower. If Husky got sued, they'd
probably drop their rating too, as would many/most other compressor
manufacturers of these small home shop compressors.
the compressor, they are the same compressor, I guess putting the
"Husky" label on the compressor gives it a 3HP boost!
jjessen
PostPosted: Mon Sep 11, 2006 10:41 am    Post subject: Compressor Recommendation Reply with quote
Yup. I got a notice about that. Keep in mind that it's really the cubic
feet per minute or second that's the key. They might exaggerate that, too,
but it'd be not as likely. Remember the days when your cool stereo amp said
it could put out 500 watts of pure music power! Ahhhhhh, the numbers game.
Go for quiet. If you've got the room and the bucks, go 220 and big tank and
quiet. Runs less and would be available for anything you'd throw at it.
John J
