sidsel.svein(at)oslo.onli Guest
Posted: Fri Sep 08, 2006 10:58 pm Post subject: Noise certificate |
<![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]> The Norwegian CAA will accept a foreign, recognized noise certificate for Europa as basis for issuing the mandatory noise certificate, instead of requiring a noise test to be performed. Do any of you have one that you could kindly e-mail to me as a scanned version, fax to my attention at +47 23 11 63 51 or mail a copy (address below). I have 912ULS with Airmaster prop (ie. three Warp blades). I would assume also a 912 or 914 would be accepted but the prop blades ought to be the same.
No rush - only needed when applying for permanent airwothiness certificate at the end of the test flying (first flight not yet performed but watch this space for imminent news!)
Best regards,
Svein
Svein K. Johnsen
Bjerkebakken 65 A
NO-0757 Oslo
Norway
