sschmidt(at)ussynthetic.c Guest
Posted: Fri Sep 08, 2006 8:18 am Post subject: Window overspray |
I had some overspray on my windows as well and used the "Scratch Off"
kit that Van's sells. I used the last two steps and it cleaned up very
nicely. In fact it looks like that section is more brilliant than the
rest. I tried water and Cee Bailey's makes a cleaner for these windows
but none of it worked.
Also, I had a small section where my DA sander hit the back window and
the scratch kit fixed it perfectly. So don't sweat it if you make a
little scratch while building or get some overspray. It will clean up.
Scott Schmidt
sschmidt(at)ussynthetic.com
