dlm46007(at)cox.net Guest
Posted: Fri Sep 08, 2006 6:40 am Post subject: engine tip |
Just got an email from www.skygeek.com. They are selling a Superior oil quick drain for $15. It is the Curtiss valve for IO540s. FAA PMA approved and compares to the SAF-DRAIN version for $50.
Tim(at)MyRV10.com Guest
Posted: Fri Sep 08, 2006 8:22 am Post subject: engine tip |
I've been using the Curtis valve on mine for the last 138 hours
with lots of good luck. Great combo with that snap-on hose.
Although, $15 is a bit high.
Aircraft Spruce
05-01872 CURTIS DRAIN VALVES CCA-1700 $11.650
05-00138 CCB-39600-1 BLK QUK DRAIN HOSE $10.80
David McNeill wrote:
| Quote: | Just got an email from www.skygeek.com <http://www.skygeek.com>. They
