jkuehn(at)mountaintime.my Guest
Posted: Wed Sep 06, 2006 8:14 am Post subject: Allegro 2000, 912UL Initial Engine Test Run |
Actually it is possible to fill the oil filter at least half way, and
quickly screw it into place. It is messy, but better than an empty
filter. Then pull the prop through, top plugs removed, followed by
spinning the engine with the starter until you get oil pressure, to
prime the system.
Jack
Dave Austin wrote:
Re oil venting..
Has anyone seen any advice on what action to take when just changing the oil
filter? It would certainly be introducing some air into the system as it
isn't possible to fill the filter with oil since it lies sideways.
SI-04-1997 dated Sept. 2002 does not address this.
Dave Austin 601HDS - 912, Spitfire Mk VIII
