Wiring Harness, GO480-G1B6, 560E
bkirkwoo(at)elp.rr.com
PostPosted: Sun Jan 22, 2006 6:11 am    Post subject: Wiring Harness, GO480-G1B6, 560E Reply with quote
I am in the process of installing a "new" engine on my 560E and would like to order a new ignition harness. Does anyone know the Champion part number that would be appropriate?
Also, in the inter-cylinder baffling there is a hole with a rubber grommet in it that appears to be where the ignition wires should be routed to the bottom cylinders. These holes weren't used in the previous installation. Should they be used? If not, should they be plugged so air doesn't go through them?
Thanks.
kamala(at)msn.com
PostPosted: Sun Jan 22, 2006 6:28 am    Post subject: Wiring Harness, GO480-G1B6, 560E Reply with quote
bk, aircraft spruce just gave me a very reasonable quote to order a wire
harness through them. mason
Reply-To: commander-list(at)matronics.com
To: <commander-list(at)matronics.com>
Subject: Wiring Harness, GO480-G1B6, 560E
Date: Sun, 22 Jan 2006 06:12:52 -0800
through them?
Thanks.
kamala(at)msn.com
bk, ps the persons name was rick morino at aircraft spruce. mason
through them?
Thanks.
