Albert Gardner
Posted: Mon Sep 04, 2006 1:46 pm Post subject: Engines? |
[quote]I have located an IO-540-M1B5D. It has several aspects that need to be changed to make it suitable for an RV-10. It has up exhaust, rear air intake, and the dual mag setup but my plan was to get a serviceable case and crank and then put new cylinder assemblies on it. I am assuming I can then get the correct sump to move the air intake forward and maybe even a different accessory cover to allow separate mags. If the case and crank are good, this might be a pretty good deal since there is a Hartzell 3 blade included. Has anyone had any success with changing sumps and/or accessory drive covers on a similar engine?Albert GardnerYuma, AZ [b]
RV-10 N991RV |
Albert Gardner
Posted: Mon Sep 04, 2006 4:03 pm Post subject: Engines? |
| Quote: | | I am reposting this note because it didn’t have any end-of-line indicators when I downloaded it and was very hard to read. So here goes-again:I have located an IO-540-M1B5D. It has several aspects that need to be changed to make it suitable for an RV-10. It has up exhaust, rear air intake, and the dual magsetup but my plan was to get a serviceable case and crank and then put new cylinder assemblies on it. I am assuming I can then get the correct sump to move the airintake forward and maybe even a different accessory cover to allow separate mags. If the case and crank are good, this might be a pretty good deal since there is a Hartzell 3 blade included. Has anyone had any success with changing sumps and/or accessory drive covers on a similar engine?Albert GardnerI have located an IO-540-M1B5D. It has several aspects that need to be changed to | 0 | Quote: | | I have located an IO-540-M1B5D. It has several aspects that need to be changed to | 1[quote] [b]
RV-10 N991RV |
jdalton77(at)comcast.net Guest
Posted: Mon Sep 04, 2006 4:34 pm Post subject: Engines? |
I've heard that Barrett Precision Engines has done this. They have a web site.
Deems Davis
Posted: Mon Sep 04, 2006 7:40 pm Post subject: Engines? |
BPE has a cold air induction system for the IO-540 which replaces the
old sump and intake manifolds.
Deems
jdalton77 wrote:
[quote] I've heard that Barrett Precision Engines has done this. They have a
web site.
