zodie(at)adelphia.net Guest
Posted: Sun Sep 03, 2006 8:35 am Post subject: Flanging Dies... plywood works OK |
I built mine from plywood scraps too, Gary.
They worked fine. Used one set of plywood flanging dies to scratch-build the whole airplane, and they're still in good shape... except the ones I trimmed too much to get into tight places.
I tried using a single bolt to draw the plywood dies together to form the flanges, but found that I had better/easier results when I squoze the dies together with some big ol' "C" clamps.
Rick Pitcher
all flanged up and flying
"squoze"???
rstone4(at)hot.rr.com Guest
Posted: Sun Sep 03, 2006 10:35 am Post subject: Flanging Dies... plywood works OK |
Hay Rick,
There are all kinds of ways to press. Did you hear about the guy who used his car. He put the flanging die under one of the front wheels and jacked the car up and down with an air driven bumper jack. All it takes is a good imagination. And the will to stick with it until you are flying an airplane you built and there is nothing like it.
Bob Stone
DO NOT ARCHIVE
n4546v(at)mindspring.com Guest
Posted: Sun Sep 03, 2006 3:28 pm Post subject: Flanging Dies... plywood works OK |
This is very "old Hat" for nearly everyone on the list, but I couldn't resist the opening, especially now that pics can be attached. Note the dies are not made of plywood!
This system worked great. I still can't emphasize enough, before flanging, sand the inside of the hole until you can run your finger around it and feel that it is perfectly smooth. Anything less and the flange will probably crack. I was in such a big hurry to try my dies that I failed to do this and wound up with two cracks in a nose rib flange. Had to make another nose rib because of this, another lesson.
Randy L. Thwing, Las Vegas, do not archive
Subject: Re: Flanging Dies... plywood works OK
Hay Rick,
Bob Stone
DO NOT ARCHIVE
315.66 KB |
283 Time(s) |
gboothe(at)calply.com Guest
Posted: Sun Sep 03, 2006 7:17 pm Post subject: Flanging Dies... plywood works OK |
Rick,
I, too, tried the C clamps on the first 3 holes. In the end I found the ball peen clamp the quickest (kinda like the “200 lb Press).
Gary
Rick Pitcher
"squoze"???
webmaster(at)upac.ca Guest
Posted: Mon Sep 04, 2006 5:26 am Post subject: Flanging Dies... plywood works OK |
Randy, I love your 1 ton press. Now that's thinking laterally! Jamie Hyneman would be proud
Trev Page
C-IDUS 601HD R912
On Sep 3, 2006, at 7:23 PM, Randy L. Thwing wrote:
[quote] This is very "old Hat" for nearly everyone on the list, but I couldn't resist the opening, especially now that pics can be attached. Note the dies are not made of plywood!
Hay Rick,
Bob Stone
DO NOT ARCHIVE
| <Gravity75dpi.jpg>
