Avionics coolingAvionics cooling
jack.lockamy(at)navy.mil
PostPosted: Wed Aug 30, 2006 6:32 am    Post subject: Avionics coolingAvionics cooling Reply with quote
I purchased and installed an inexpensive ($1Cool 12-volt fan from Radio Shack. Here is a link:
http://www.radioshack.com/product/index.jsp?productId=2102826&cp=&origkw=fan&kw=fan&parentPage=search
Built a small bracket and mounted it on a rib behind the avionics stack. It is powered on automatically when I turn the Avionics Master switch on. It's quiet, small, lightweight, and seems to be doing the job.
Just another suggestion...
Jack Lockamy
Camarillo, CA
RV-7A N174JL 220 hrs
RV-10... maybe
www.jacklockamy.com [quote][b]
wayne.e(at)grandecom.net
PostPosted: Thu Aug 31, 2006 2:58 am    Post subject: Avionics coolingAvionics cooling Reply with quote
I'm having Stein install avionics cooling fans for my panel but I also have put in a couple of computer fans in the glare shield for defrosting but I think this will also allow for some of the heat coming from the avionics to vent through these holes. I've attached a photo of the holes in my glare shield. The picture was before I installed the fans. I think these holes will also help with the cooling process.
Wayne Edgerton #40336
 Filesize:  92.8 KB
 Viewed:  192 Time(s)
coop85(at)bellsouth.net
PostPosted: Thu Aug 31, 2006 3:44 am    Post subject: Avionics coolingAvionics cooling Reply with quote
Wayne,
The glare shield looks great, very nice work. I wish I had prepped mine better prior to putting on the windscreen. I got a little too exited about making progress and it definitely made life tougher.
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Thursday, August 31, 2006 6:58 AM
Subject: Re: Avionics coolingAvionics cooling
