kerrjohna(at)comcast.net Guest
Posted: Mon Aug 21, 2006 8:55 am Post subject: ALtimeter adjustment |
Some of you may remember a thread a couple of months ago regarding a mystery marker(bug) that moved around the circumference of a old altimeter. While at OSH I asked one of the intrument dealers there about it. Apparently, it is a pressure altitude indicator used on (much) higher performance aircraft.
Thanks for asking that Gary. I have the same issue with my altimeter. Seems like I'm adjusting it constantly to the GPS. It's so far out of whack that barometric pressure reading has vanished form Kollsman window. I tried removing the little screw next to the Kollsman adjustment knob (figuring it was a calibration screw) and spent the next hour putting the little parts back in that came shooting out.
By the way. I've also experience pilot side tank emptying faster. I have noticed that fuel cap on that side vents better than the other one. Don't know if that's the cause or a tendency to fly left wing high. I'm going to swap caps and see if it makes a diff.
Algate <algate(at)attglobal.net> wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) } Thanks Don and Shane,
I think that you are both probably right and I am probably chasing red herrings. As I am new to this plane I am probably just being over critical. I knew my last Kitfox inside out and trusted it implicitly I guess I am just going to have to build up the same confidence level with this one.
Another question I found an adjustment for my VSI but not for the altimeter is there a user friendly way to adjust these or is it an instrument technician job. My altimeter reads almost 600ft out !
Gary Algate
From: <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Shane Sather
Sent: Monday, August 21, 2006 9:51 AM
Subject: Re: RE: Kitfox-Fuel Flow
Gary I notice the same difference on my Light 2 also but not to the same extent. The pilot side always goes lower first. This has been noted by many others too and I don't recall that there was any real solution for this
Shane.
Posted: Mon Aug 21, 2006 10:23 am Post subject: ALtimeter adjustment |
Yes, mystery solved,
Kurt S.
--- kerrjohna(at)comcast.net wrote:
| Quote: | Some of you may remember a thread a couple of months
aircraft.
Posted: Mon Aug 21, 2006 10:56 am Post subject: ALtimeter adjustment |
Yes, donīt remove the altimeter screw. I did that
too. Just loosen. It takes a bit of jiggling to
disengage the gears and the same to get them
reengaged. I believe you set the altitude first, then
pull the knob to reset the window only, then push
while wiggling to reengage the gears and then tighten
the screw.
Kurt S.
mike Guest
Posted: Mon Aug 21, 2006 11:03 am Post subject: Re: ALtimeter adjustment |
I would never adjust my vertical to the GPS, why it's not all that accurate. I can fly around the larger airports and fall within 100ft., but if I leave the area and fly lets say outside 25 miles from the airport, the veritical is 300ft off. Another concern is where you are pulling the static port, under the dash and the altimiter is off about 100, outside the plane is generally most accurate. I've played between inside and outside and both vertical and airspeed is affected a bunch.
msm_9949(at)yahoo.com Guest
Posted: Mon Aug 21, 2006 11:39 am Post subject: ALtimeter adjustment |
Static port is on left fuse toward the tail. All other static instruments work fine. I'm pretty sure altimeter just needs a little calibration.
kitfoxmike <kitfoxmike(at)yahoo.com> wrote:
[quote]--> Kitfox-List message posted by: "kitfoxmike"
kitfoxmike
kitfox4 1200 [url=http://us.rd.yahoo.com/evt=43256/*http://advision.webevents.yahoo.com/mailbeta] All-new Yahoo! Mail [/url]- Fire up a more powerful email and get things done faster. [quote][b]
Posted: Mon Aug 21, 2006 11:52 am Post subject: ALtimeter adjustment |
has anyone had a problem with the recommended location of the static port on a Classic IV? On take off, altitude drops +/- 100 feet as I get near rotation speed.
John Kerr
[quote] --> Kitfox-List message posted by: "kitfoxmike"
kitfoxmike
kitfox4 1200 912ul speedster
http://www.frappr.com/kitfoxmike
rv7 wingkit
reserv WIKI [quote][b]
AMuller589(at)AOL.COM Guest
Posted: Mon Aug 21, 2006 12:05 pm Post subject: ALtimeter adjustment |
If your altitude changes from runway altitude during acceleration for takeoff and rotation your static port is in a bad location. Ours is a dual port system flushmounted on the fuselage just under each door just below where a pilots hand would be if the arm was hung out the doors. The GPS altitude is not accurate enough for legal altimeter settings and if you monitor it in a stationary position you will notice it varies quite a bit. Here in Houston at 23 ft msl it has varied a hundred feet or so If your altimeter is in error by plus or minus 75 feet it should not be used.
Posted: Mon Aug 21, 2006 12:38 pm Post subject: ALtimeter adjustment |
Actually, mine was a bit more complicated. Instrument had to come out of the airplane. The screw on face of instrument had to come out completely and the pin it screwed into, disengaged from the knob post before the knob would pull out. Pulling knob out while turning it moves the Kollsman window altimeter reading, so set your known elevation first, then pull out knob and set altimeter.
Now, does anyone know how to calibrate an rpm gauge? I have an ACS cheapo that reads 500 with the engine shut down.
kurt schrader <smokey_bear_40220(at)yahoo.com> wrote:
[quote]--> Kitfox-List message posted by: kurt schrader
disengage the gears and the same to get [quote][b]
mike Guest
Posted: Mon Aug 21, 2006 1:28 pm Post subject: Re: ALtimeter adjustment |
The only way I would mess with an my vertical is to set altimeter and then adjust to known altitude on the ground. If there are any other problems, send the unit in for repairs or replace. My static is where skystar put it in the plans. I also have a transponder and my altitude is what shows on the radar. Well, within 100ft. anyway. I don't care if it's that percise. But the main thing is it doesn't vary while I'm flying. But the Gps does. Like I said earlier, the Gps will loose out the farther I get away from the big airport. I think either my Gps needs to be hooked to an external entenna, or the accuracy is dropped as you get away from the big airports. You know, classC and classB airports.
Float Flyr
Posted: Tue Aug 22, 2006 4:51 am Post subject: ALtimeter adjustment |
Thanks for the reminder. I had been planning on resetting my Altimeter for
a long time now and never seemed to get around to it. While I was at it I
did the VSI the next step is a compass swing... Not too easy on floats.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Tue Aug 22, 2006 5:08 am Post subject: ALtimeter adjustment |
If the tach is mechanical then it's done by internally adjusting the tension on screws. Some have spring tension adjusters some have to replace the springs. these units are lovely to look at but are quite heavy as are the drive cables etc. when new they are known to be quite accurate.
If it's early electrical it may have a variable resistor that can be adjusted. On these meter type tachs you may also have to set the "0" mark on the face of the meter. Before fooling with any internal settings I would check on the zero set (it's a little screw at the base of the meter hand) first. disturbing any of the internal resistors will affect the linearity of the instrument. Ever calibrate a tach???? Me neither.
If the tach hand swings through an arc of more than 90deg. there may also be a gear network associated with the pointer. This is a place where friction can occur making the tach a bit sluggish. Lubricating those gears and pivots is not recommended.
If the tach is digital it's probably right on but you may have to filter noise off the tach line. Some times ignition noise on the tach input line can be read as extra pulses by the tach making it read high. Check the archives for fixes. some have added resistors to the input line to filter out noise.
Noel [quote]
Kitfox III-A
dave(at)cfisher.com Guest
Posted: Tue Aug 22, 2006 5:23 am Post subject: ALtimeter adjustment |
Hi ,
On tachs- get a tiny tach. They have proven most accuarte as they measure off the spark plug wire.
ACS tachs - I do not know but I do know that Rotax tachs can read erractic as hell.
Dave
47 years old
582 IV
Float Flyr
Posted: Tue Aug 22, 2006 5:28 am Post subject: ALtimeter adjustment |
Be careful with the transponder altitude encoder.
The encoder is always set at 29.92 for IFR readings. That way all aircraft
encoders will read the same altitude in a given location. Well that's the
idea any way. When you get an altitude report form FSS they are reading
back to you the info your encoder has sent them mode "C".
At VFR altitudes deviations from 29.92"hg. Will give discrepancies in your
encoder info. A problem with this info is all it requires is for a partial
blockage of a static port to occur and the info reported to you by FSS will
be wrong.
If you subscribe to the GPS nav systems that airports are installing. Then
your altitude should be corrected for several miles around that airport.
Other than that I wouldn't trust it at all. GPS is a great system except it
is military controlled and we get dependant on it. For short distances I
love to fly VFR I have even navigated to an extent by the sun and got close
enough to see my destination.
Noel
[quote] --
Kitfox III-A
mike Guest
Posted: Tue Aug 22, 2006 6:08 am Post subject: Re: ALtimeter adjustment |
What's the big deal on altitude any way, I fly out the window, and if your going into an off field (remote landing) landing you have no idea what the altitude is, and that GPS should not be trusted for this, for reasons I mentioned earlier. You need to know your altitude by looking out the window. The other day I flew into such an air stip that my wife was sitting in the right seat holding on and just figiting the whole way down. I cleared all trees by about 20ft. but she couldn't take the closeness or the look of what I was doing. That's where doing short landings at your airport comes in handy. You can judge your height and if needed glance down at the altitude for reference to make yourself better at it. As far as the encoder, I use that as a reference to prove that the altitude indicator does not change, but the Gps will vary for reference, if that makes sense. I never rely on the encoder for accuracy, just to show that the altitude indicator isn't loosing accuracy through the flight. THat's why you always give your altitude when getting clearance with atc, so that things can be zero'd so to speak with the controller.
Float Flyr
Posted: Tue Aug 22, 2006 8:01 am Post subject: ALtimeter adjustment |
Good Idea...I did that last year! works great for me.
Noel [quote]
Kitfox III-A
Lynn Matteson
Posted: Tue Aug 22, 2006 12:38 pm Post subject: ALtimeter adjustment |
Noel-
I was advised to fly the plane, and align it with hedge rows....N-S and
E-W. I tried this last night, but some of the rows curved, so I'm not
sure how accurate this advice is. I first tried to set the compass
using the GPS, but was tracking wrong for this to work. If you set it
on the ground, how do you make sure the plane is exactly aligned with
the compass rose? And in your case, floats, ??????
Lynn
Altimeter for
it I
Noel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Tue Aug 22, 2006 4:34 pm Post subject: ALtimeter adjustment |
I forgot to mention alignment on wheels without a compass rose. Well you
are supposed to use a calibrated reference compass to set out a compass rose
before you start or use a reverse heading sighting compass to set the
heading of the plane. Head the plane North Mag, Zero the compass until the
card points North (zero deviation). Then turn the plane to the East and set
the compass E-W to read 90 degrees. Now turn the plane south and remove
ONLY HALF of the correction to make the compass read South. You guessed it
turn to the west and remove ONLY HALF the E-W correction that would make
the compass read West. Now turn the plane to the North again and read the
compass that reading is what is supposed to be on the compass correction
card. Keep turning the plane in 45 deg increments recording the compass
readings at each point. Prepare the compass correction card.
Points to remember....
If you use the special sighting compass (Also calibrated) that reads in
reverse be sure to "shoot" the plane's direction from more than 30' in front
of the plane.
The compass should be level while making the corrections and the readings.
You can either jack up the tail or just swivel the compass to do this. An
in dash installed compass will require you to raise the tail at each
direction.
Use a non ferrous screw driver to make the adjustments. (Thought I'd miss
that one didn't you.)
There is one sure way to tell that a compass swing has been done with the
sole use of a BIC pen. The for 0 deg, head 0deg is a real give away. (If
you are going to cook the books at least do it right.)
Engine should be running (over 1000rpm.) and normal in flight electrical
equipment should be turned on.
Nothing too difficult until you have to do it on floats.
Noel
[quote] --
Kitfox III-A
AMuller589(at)aol.com Guest
Posted: Tue Aug 22, 2006 4:46 pm Post subject: ALtimeter adjustment |
compass swings: after the major headings are logged use the D.G. inflight to calibrate the individual 10 deg if desired.
Float Flyr
Posted: Tue Aug 22, 2006 5:04 pm Post subject: ALtimeter adjustment |
To swing a compass properly on floats requires that you know the area you
are setting up in very well and that you have almost glassy water
conditions. You have to pick your headings and then while under way make
the compass adjustments. I suppose it could be done with an anchor attached
to the tail of the plane then use the rudder to set up directions. The
problem is you are supposed to line the aircraft up accurately and you are
supposed to operate the engine and in flight electrical equipment. The only
way I can see it being done is to have two persons doing the swing, one to
handle the plane and one to make the adjustments to the compass.
Now for the truth....
The decision on what is straight is subjective. Very few planes are
completely symmetrical. What the pilot perceives as straight is also
subjective and of course there is the whole question of parallax
correction..... The ability to hold a heading within a couple of degrees
on a magnetic compass in a noisy and some what busy or bumpy cockpit is
difficult. For most people if the compass points "more or less" north it's
ok. I know of pilots who have never even looked at their compass cards even
though there has to be a recent compass card on board here in Canada and a
compass swing is part of an annual inspection. I doubt they ever use their
compasses. Now with the advent of GPS....
The obvious short cut is to do the swing while the plane is on the trailer
of course you will have to accept some error. Unless you know of some one
who has a composite trailer.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Tue Aug 22, 2006 6:23 pm Post subject: ALtimeter adjustment |
The work is in adjusting the four primary cardinal points
All you need is a DG and something to reference it to. Neat idea.
Noel [quote]
Kitfox III-A
