Propeller lug extraction
kheindl(at)msn.com
PostPosted: Tue Aug 22, 2006 8:48 am    Post subject: Propeller lug extraction Reply with quote
Would anyone be able to help by loaning or selling me a tool for extracting
the tightly fitting lugs for the propeller attachment bolts, which are used
for the standard Warp Drive prop ?
I understand that Airmaster supply such a tool as part of their kit.
I am having a terrible time getting my Woodcomp propeller to work, vibration
being only one of the problems. I removed the lugs once but damaged them in
the process, and have remounted the WD with a new set of Rotax supplied
lugs. Now I would like to try the Woodcomp again.
Many thanks,
Karl
jeff(at)rmmm.net
PostPosted: Tue Aug 22, 2006 9:32 am    Post subject: Propeller lug extraction Reply with quote
Karl,
I don't have the tool but I do have an extra set of lugs if that would
help. I am in the US though.
Jeff
A258 Flying Off The 40
Do Not Archive.
extracting the tightly fitting lugs for the propeller attachment
bolts, which are used for the standard Warp Drive prop ?
vibration being only one of the problems. I removed the lugs once but
damaged them in the process, and have remounted the WD with a new set
of Rotax supplied lugs. Now I would like to try the Woodcomp again.
Many thanks,
Karl
kheindl(at)msn.com
PostPosted: Tue Aug 22, 2006 11:16 am    Post subject: Propeller lug extraction Reply with quote
That is very kind of you, Jeff, but you had better hang on to them. I just
paid $ 90 for a set.
Karl
Reply-To: europa-list(at)matronics.com
Subject: Re: Propeller lug extraction
Date: Tue, 22 Aug 2006 12:30:46 -0500
Karl,
Jeff
Do Not Archive.
>extracting the tightly fitting lugs for the propeller attachment bolts,
>damaged them in the process, and have remounted the WD with a new set of
>Many thanks,
>Karl
kheindl(at)msn.com
PostPosted: Tue Aug 22, 2006 3:22 pm    Post subject: Propeller lug extraction Reply with quote
Thank you all for responding so quickly to my request. Someone has offered
to mail me the tool already, so I can relax.
Karl
Date: Tue, 22 Aug 2006 20:14:09 +0100
Karl
>From: JEFF ROBERTS <jeff(at)rmmm.net>
>Karl,
>Regards,
>Jeff
>Do Not Archive.
>>Many thanks,
>>Karl
