dennisvh
Posted: Mon Aug 21, 2006 6:26 pm Post subject: RPM drop Problem |
I have a 1946 Ercoupe with a 85 hp Continental Engine with a 200 RPM drop on the right mag. Mechanics have 100% eliminated both mags, all plugs, p-leads and switching system. Also, the engine ran perfectly for the last 25 hours after a new wiring harness was installed. I would appreciate any advice on where to look next to solve this problem.
Dennis Hatfield
| | - The Matronics Continental-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Continental-List |
RBartholomeee(at)comcast. Guest
Posted: Tue Aug 22, 2006 2:39 am Post subject: RPM drop Problem |
Sounds like the only thing left that is electrical is the plug wires. Try
unhooking them 1 at a time. To find the weak/bad cyclinder warm up the
engine for a minute or 2 on the bad mag. The bad cylinder should be cooler.
Spray wd40 on the exhaust stacks to find the cooler one. Once you find the
bad xyxlinder swith the plugs then wires with a good cyclinder and see if
the probem moves. If not it may be a bad lifter or valve.
Roger (at) MD43 C150
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
