MichaelGibbs(at)cox.net Guest
Posted: Sat Aug 19, 2006 3:16 pm Post subject: Ethanol and wing tanks Ethanol and wing tanks |
Noel sez:
| Quote: | The first link to chevron was dead so it sent me to their search page.
Apparently, it picked up a "%3E" on the end somehow. This is the correct link:
<http://www.chevron.com/products/prodserv/fuels/bulletin/aviationfuel/9_ag_specsandtest.shtm>
| Quote: | The second
page...<<http://www.prime-mover.org/Engines/GArticles/octane.html> >...said
exactly what I've been saying on this thread. Any fuel that has more
resistance to detonation than octane will have an octane rating
higher than 100.
I guess you missed this part:
"HOW DO THEY GET OCTANE NUMBERS ABOVE 100?
"Often it's done by pure extrapolation. A more reliable method,
however, is through the use of so-called performance numbers.
Briefly, these are arrived at by determining the instantaneous mean
effective cylinder pressure (IMEP), using the fuel under test, at the
highest boost that does not cause knocking. This number is then
multiplied by 100 and the resultant is divided by the IMEP at the
highest boost that does not cause knocking on the 100 octane
equivalent fuel.
"Note that, technically, there is no such thing as an octane number
above 100. If you're at a party, avoid saying things like '110 octane
gasoline' because people will get up and walk away from you. You
should say, instead, 'a gasoline with a performance number of 110.'
That will bring the help scurrying over with more champagne."
| Quote: | I guess to try to cut to the quick of it is that it looks to me that
you are trying to compare apples to oranges.
I don't know why you think that. I just pointed out the definition
of octane rating versus other performance ratings. I have no agenda
on volatility or flash points.
Mike G.
N728KF
Float Flyr
Posted: Sun Aug 20, 2006 4:40 pm Post subject: Ethanol and wing tanks Ethanol and wing tanks |
Noel
equivalent fuel.
**I agree. This is factual. And what they are getting at is a rating is
simply a comparison.
| Quote: | "Note that, technically, there is no such thing as an octane number
**Viva La Champagne! Can I get dark rum with that? Technically we are
getting into semantics a bit but you're right again.
| Quote: | I don't know why you think that. I just pointed out the definition
**I believe your word was octane <<percentage>> I was talking about "rating"
so extrapolation or mathematical assessment is all that is available. E.g.
Some gasoline available today may not have any octane at all. Would their
octane rating be "0"???, How does one then assign an octane rating to
ethanol??? Is there any heptanes in 100 octane gas, or should I call it
motor fuel??
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Sun Aug 20, 2006 11:42 pm Post subject: Ethanol and wing tanks Ethanol and wing tanks |
Noel sez:
| Quote: | **I believe your word was octane percentage I was talking about
"rating" so extrapolation or mathematical assessment is all that is
available. E.g. Some gasoline available today may not have any
octane at all. Would their octane rating be "0"???...
This is going to take a long time if I have to keep spoon-feeding the
article to you one paragraph at a time. The first sentence says
<http://www.prime-mover.org/Engines/GArticles/octane.html>:
"The octane number assigned to a motor fuel has very little to do
with the actual chemical "octanes" in the fuel..."
My use of the term "percentage" referred to the percentage of
iso-octane to heptane, which is the definition of "octane rating,"
not octanes as a substance.
| Quote: | How does one then assign an octane rating to ethanol???
From the same article:
"...you run your reference fuel, made up of various proportions of
heptane and iso-octane through the ASTM-CFR. You keep varying the
proportion of heptane to iso-octane until you get a fuel that behaves
just like (knock-wise) your mystery fuel. Once you get that, you say
to yourself 'How much heptane did I have to add to the iso-octane to
get the mixture to knock in the ASTM-CFR just like my mystery fuel?'
If the answer is, say, 10% heptane to 90% iso-octane, your mystery
fuel has an octane number of 90...
equivalent fuel."
Mike G.
728KF
Float Flyr
occom(at)ns.sympatico.ca Guest
Posted: Mon Aug 21, 2006 8:05 am Post subject: Ethanol and wing tanks Ethanol and wing tanks |
I always looked at octane ratings as just a number based on some math that
never mattered to me. Very much like proof numbers on your dark rum it has
some relationship to a percentage and more may be better depending on your
goal. Now, how do we keep either from destroying our tanks and plumbing!
Posted: Mon Aug 21, 2006 11:59 pm Post subject: Ethanol and wing tanks Ethanol and wing tanks |
Noel sez:
| Quote: | > "The octane number assigned to a motor fuel has very little to do
** That is the reason that it is possible to have an octane rating
of more than 100.
Now about that Champagne.....
Sorry Noel, no champagne for you
should say, instead, 'a gasoline with a performance number of 110.'"
Lowell sez:
| Quote: | At least the rest of us understand.
Thanks Lowell.
Mike G.
N728KF
Float Flyr
Posted: Tue Aug 22, 2006 5:46 am Post subject: Ethanol and wing tanks Ethanol and wing tanks |
No where in that piece did it say the octane number can't go above 100. It
did say it was an empirical measurement (based on observation or theory,
Concise Oxford Dictionary)
Noel
[quote] --
Kitfox III-A
Posted: Wed Aug 23, 2006 12:05 am Post subject: Ethanol and wing tanks Ethanol and wing tanks |
Noel sez:
| Quote: | No where in that piece did it say the octane number can't go above 100.
I don't know what you are smoking, Noel, but it must be good stuff.
I copied this DIRECTLY from the article:
> above 100.
Mike G.
N728KF
Float Flyr
Posted: Wed Aug 23, 2006 5:25 am Post subject: Ethanol and wing tanks Ethanol and wing tanks |
Haven't had a cigarette in sixteen years .... But I did have a cigar this
weekend ( the first one in about 15 yr.)
Technically you may be right practically tell that to all the guys who
burned tons of octane 110-115
Technically by that definition if the fuel doesn't have iso-octane in it the
octane rating is zero
Technically they're playing with semantics.
Noel
P.S. Think I'll go flying 8^}
[quote] --
Kitfox III-A
valley361(at)centurytel.n Guest
Posted: Wed Aug 23, 2006 6:01 pm Post subject: Ethanol and wing tanks Ethanol and wing tanks |
List,
Way back when in mechanics school at Navy Memphis, students were
told that fuel ratings above 100 were performance numbers. 115/145, 100/130,
rich and lean.
As for Newfoundland. I spent a lifetime there one year (Argentia).
do not archive Jay C.
Lyle Persels
Posted: Wed Aug 23, 2006 6:47 pm Post subject: Ethanol and wing tanks Ethanol and wing tanks |
Jay,
I flew those fuel ratings for 25 years in the Navy and never knew
what they meant. We learn so much late in life, mainly that the
things we knew for certain when we were young were entirely wrong,
and the that the things we know now represent only our current state
of understanding, certain to change if we live long enough.
Lyle
Do not archive.
On 08 23, 06, at 9:01 PM, Jay Carter wrote:
<valley361(at)centurytel.net>
List,
were
100/130,
rich and lean.
(Argentia).
Float Flyr
Posted: Wed Aug 23, 2006 6:57 pm Post subject: Ethanol and wing tanks Ethanol and wing tanks |
I spent a year in Placentia...You know where that is. We, the construction
crew I was on, used to hit the club on base every Friday afternoon. D(at)#$ if
I can remember the name of it. Maybe the Windjammer.
I once had a conversation with a "Full Bird Colonel who said they used
Argentia to re-introduce service men to civilization after particularly hard
isolated postings like Greenland.
Not the end of the world.... But you can smell it from there ;^}
Noel
[quote] --
Kitfox III-A
