My Tunnel Heat Fix
ScooterF15
PostPosted: Thu Aug 17, 2006 8:38 pm    Post subject: My Tunnel Heat Fix Reply with quote
Second try to post this message:
.AOLPlainTextBody { margin: 0px; font-family: Tahoma, Verdana, Arial, Sans-Serif; font-size: 12px; color: #000; background-color: #fff; } .AOLPlainTextBody pre { font-size: 9pt; } .AOLInlineAttachment { margin: 10px; } .AOLAttachmentHeader { font: 11px arial; border: 1px solid #7DA8D4; background: #F9F9F9; } .AOLAttachmentHeader .Title { font: 11px arial; background: #B5DDFA; padding: 3px 3px 3px 3px; } .AOLAttachmentHeader .FieldLabel { font: 11px arial; color: #000000; padding: 1px 10px 1px 9px; background: #F9F9F9; } .AOLAttachmentHeader .FieldValue { font: 11px arial; color: #000000; background: #F9F9F9; } .AOLAttachmentHeader a, .AOLImage a { color: #2864B4; text-decoration: none; } .AOLAttachmentHeader a:hover, .AOLImage a:hover { color: #2864B4; text-decoration: underline; } body { background-color: white; font-family: "Verdana"; font-size: 10pt; border: 0px; } p { margin: 0px; padding: 0px; } img.managedImg { width: 0px; height: 0px; } img.placeholder { width: 275px; height: 206px; background: #F4F4F4 center center no-repeat; border: 1px solid #DADAD6 !important; } On my first 3 flights the tunnel got very warm. You could still hold your hand on it (just barely) but it was hot in there. Additionally, the belly of the aircraft just aft of the cowling was HOT after the flight. Now that I've made some easy changes the tunnel is cool to lukewarm and there is no appreciable heat on the belly after flight. I've been flying in 80 to 90+ degree weather with the heater scat tubing connected.
I heard about the tunnel heat problem a little late and I built only a few preemptive things into the plane. I put ceramic gaskets behind the heater valves to keep heat from transfering to the firewall/tunnel. I installed a blast tube on the firewall forward of the tunnel. And I installed a computer fan in the tunnel cover just over the fuel pump (this actually made a big difference in tunnel heat once I turned it on.)
These things didn't fix the problem, but here's what did. I was having CHT and oil temp overheating problems and one of the things I did to fix this problem was increase the cowl air exit area to improve air flow. As you can see from the photo I enlarged one of the louvers and added an additional one - this didn't make much difference alone. Then I trimmed the aft edge of the "reverse scoop" forward about an inch (see photo). This increases the exit area, but I think it also allows the hot air to move down and away from the fuse and disipate faster.
I'm sure that I added extra drag to my plane, but the engine and tunnel are now cool.
Jim McGrew
40134 - flying
[Image Removed]
 Filesize:  38.57 KB
 Viewed:  723 Time(s)
Tim(at)MyRV10.com
PostPosted: Thu Aug 17, 2006 9:18 pm    Post subject: My Tunnel Heat Fix Reply with quote
Congrats on the fix! That really doesn't look bad at all.
I wonder if just trimming that aft 1" of the cowl alone would
improve things the majority of what you noticed.
At any rate, it's great to see someone trying different things.
I didn't have the problem, but decided to try to make things
as cool as possible. If forgot to add this link to my list
tonight, but here are some vetterman exhaust extensions I added.
http://www.myrv10.com/N104CD/upgrades/20060807/index.html
For people who saw it at OSH, you could really tell that my
pipes were shorter than the newest ones. And, not wanting
to miss out on the "mine is longer" competition, I decided to
give it a whirl. No real change. I may just try hacking off
that rear 1" though...that seems really simple and reasonable.
are now cool.
Jim McGrew
40134 - flying
[Image Removed]
coop85(at)bellsouth.net
PostPosted: Fri Aug 18, 2006 3:58 am    Post subject: My Tunnel Heat Fix Reply with quote
Jim,
Great fix and I’m glad it worked so well, may end up doing that myself. The really impressive thing is the nerve to make the changes since they would be tough to undo. That’s the great thing about homebuilts, think of a fix and act on it. Not everyone would have the conviction to do it though – great job!
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jsmcgrew(at)aol.com
Sent: Thursday, August 17, 2006 3:59 PM
Subject: My Tunnel Heat Fix
Jim McGrew
40134 - flying
[Image Removed]
