gert.v(at)sbcglobal.net Guest
Posted: Thu Aug 10, 2006 7:27 pm Post subject: io360-a1b |
Hi Folks
can anybody tell me the difference between the 06A19956 and STD2217 oil
seals, both are 7/8" i.d. x 1-1/2" o.d. x 5/16" wide.
according to the parts book, my vacuum pump adapter should have the
06A19956 seal, but has the STD2217 seal and it needs replacing,
also, in the parts book, page 2-4 of the parts manual, it shows steel
ring #3 to sit on top of the drive gear, under the tail of #16. However
on page 5-4 of the overhaul manual as well as on page 1-23 of the limits
and torque supplement, it shows the steel ring under the snapring
holding the shaft in place. I looked at two adapters, and wouldn't u
know, one had the ring on top and one had the ring at the bottom.
Anybody knows the correct placement??
any input greatly appreciated.
Gert
Pursuant to US Code, Title 47, Chapter 5, Subchapter II, '227,
any and all nonsolicited commercial E-mail sent to this address
is subject to a download and archival fee in the amount of $500
US. E-mailing denotes acceptance of these terms.
Rhonda(at)bpaengines.com Guest
Posted: Fri Aug 11, 2006 5:20 am Post subject: io360-a1b |
The 06A19956 part number is the superceding p/n for STD-2217 according
to the Lycoming Parts History manual. Probably no difference other than
who the vendor is that was used to produce the part number, or a process
change in how the seal was manufactured.
Rhonda
Posted: Sat Aug 12, 2006 10:43 am Post subject: io360-a1b |
Thanks Rhonda
any resolution on the correct position of the steel ring in the governor
drive adapter??
Gert
Rhonda
BPA(at)bpaengines.com Guest
Posted: Tue Aug 15, 2006 7:23 am Post subject: io360-a1b |
The governor drive shaft has a thrust surface, therefore the 'steel
ring' which is actually a thrust washer installs between the housing and
retaining ring. The picture in some of the parts catalogs that show the
ring directly under the gear end of the drive shaft is a typo.
Allen Barrett
BPE, Inc.
