evmeg(at)snowcrest.net Guest
Posted: Sun Aug 13, 2006 9:37 am Post subject: wing fillets |
UH OH! Be careful here guys...Talk to the guys at Vans before you put any
wing fillets on your airplane. There have in the past been discussions about
this causing some odd flight characteristics...I believe Van himself wrote
an article on the subject a few years back in an RV ator..... Despite
popular opinion, those engineers DO know more about these planes than any
other group of experts. If you know what you are doing and understand the
consequences then by all means knock yourself out with the mods...the rest
of us should build it the way it was designed.
Cheers..
Evan Johnson
www.evansaviationproducts.com
(530)247-0375
(530)351-1776 cell
cjensen(at)dts9000.com Guest
Posted: Sun Aug 13, 2006 10:55 am Post subject: wing fillets |
I assumed Nic's reference to the wing/fuselage design deficiency was due to the 90 degree intersection, which is well understood to be 'draggy' and not as efficient as a faired/filleted one. But the fillet negatively impacts flight characteristics? Any further info on that or was it just a recollection to that effect?
Chuck
Posted: Sun Aug 13, 2006 1:40 pm Post subject: wing fillets |
Just a recollection.....so take it at face value. As I recall it had
something to do with flutter problems on RV8 in particular. Maybe I dreamed
the whole thing but I don't think so....worth a call to the home base to
find out before you do such a thing.
Evan
martin(at)gbonline.com Guest
Posted: Mon Aug 14, 2006 6:25 am Post subject: wing fillets |
All listers,
When I was near the completion of my RV8 SN2 in 1999, I considered the
large fillets for my RV8. Fortunately at that time EAA was running a series
of articles in Sport Aviation featuring the series of tests that were being
run by the CAFE group in California ( I think) on the efficiency of wing
fillets vs the square cut juncture as used by Vans on the RV8. It was the
conclusion in this article that the square cut junction was better than the
large fillet. I am sorry that I cannot recall the exact issue of SA for all
of you to research, however perhaps some of you who are computer experts
can find that article in the archives of Sport Aviation.
Dick Martin
RV8 N233M
the fast one
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Mon Aug 14, 2006 11:04 am Post subject: wing fillets |
Actually Chuck, you've got the drag part backwards. It goes against
intuition but in theory, a non-filleted 90 deg intersection is the
lowest drag. The RV is close enough to 90 deg that the fillet will
increase drag. The F4U Corsair used it - bent wing and round fuselage
gave them a perfect 90 deg intersection - no fillets needed. Van and
Chance Vought knew what they were doing. Flight characteristic changes
with fillets are a different thing and could be good or bad.
Greg Young
Chuck
Posted: Mon Aug 14, 2006 1:15 pm Post subject: wing fillets |
I'll be....not the first, and certainly not the last thing that I've had
backwards. I have no idea where I came up with the belief that a fillet
would reduce drag over a 90 degree intersection--probably the same place
that a lot of people come up with their 'aeronautical' ideas.
Thanks for setting me straight...I wondered why the cart was out head of
the horse!!!
Chuck Jensen
against intuition but in theory, a non-filleted 90 deg
intersection is the lowest drag. The RV is close enough to 90
deg that the fillet will increase drag. The F4U Corsair used
it - bent wing and round fuselage gave them a perfect 90 deg
intersection - no fillets needed. Van and Chance Vought knew
what they were doing. Flight characteristic changes with
gcomfo(at)tc3net.com Guest
Posted: Mon Aug 14, 2006 3:34 pm Post subject: wing fillets |
dbris200(at)sbcglobal.net Guest
Posted: Mon Aug 14, 2006 4:49 pm Post subject: wing fillets |
I believe the problem associated with the fairings on the 8 was that when they were left off completely, the turbulence had a very negative effect on the tail. I don't recall anything about the shape affecting the handling on the 8.
Dave
Evan and Megan Johnson wrote: [quote] [quote]--> RV-List message posted by: "Evan and Megan Johnson" <evmeg(at)snowcrest.net> (evmeg(at)snowcrest.net) Just a recollection.....so take it at face value. As I recall it had something to do with flutter problems on RV8 in particular. Maybe I dreamed the whole thing but I don't think so....worth a call to the home base to find out before you do such a thing. Evan ---
gmcjetpilot(at)yahoo.com Guest
Posted: Tue Aug 15, 2006 12:09 pm Post subject: wing fillets |
I don't think anyone did formal analysis of the wing fillet or wrote and
article. I know cafe foundation did not do a report. If any SA article
was printed I don't recall any detail analysis or comparison. However
I do know a RV'er who tried it and went back to stock wing-body
faring because he found no measurable change in performance.
One thing no one mentioned is when you install one of these big
wing junction fairings you introduce a bunch of small detail. You end
up with another edge along the fuselage and extra fasteners. Usually
made of fiberglass, the aftermarket fairings have more thickness at
the edge where the fairing laps over the wing and fuselage. The
stock aluminum fairing is very thin and has no edge lapped up onto
the fuselage.
Just from the above EDGE FACTOR" what ever gain you get will
likely be negated buy extra drag from the installation. If you have a
custom wing to side of body fairing you may be able to feather all
edges making this less of an issue, at the expense of extra work and
possible body fillers.
I hear the theories about the wing is near 90 degrees and the Corsair
F4U and other comments, which may be true, but until you do wind
tunnel work or better flight test, you don't know.
A well designed and installed (no draggy details) wing root fillet
fairing could improve "intersection drag". I say COULD, but like all
things in aerospace design there are trade-offs, compromises and
the famous no free lunch rule.
Gain verses extra weight and more details? Even if perfectly
executed, it's likely this modification will produce only small benefit.
The off the shelf fairings are too small (radius wise) and have poor
installation details. The fairing should blend right into the mating
surfaces of the wing and fuselage with no edge or protruding
fasteners.
The plan flat stock Van's set up provides a light weight, simple, least
attach hardware and holes. As far as drag it is pretty good and if you
could improve it in any way with a swoopy fillet, wing root to body
junction faring, it would be hard to measure.
Often fiberglass fairings start to warp and gap after time, especially
a big wing body fairing with long straight edges. I had the ORIGINAL
fillet wing/body faring on my RV-4, which had a wrap-around fiberglass
wing leading edge cuff. The remainder of the fairing was made with
aluminum sheet fillet on top, flat aluminum on bottom. As with Van's
designs, it was pretty darn good. Again you still need fasteners in the
fuselage. It was OK, but I replace it with the newer style flat faring; it
was just cleaner looking. I did not do a before after because I made
several changes at the same time.
George RV-4/RV-7
Stay in the know. Pulse on the new Yahoo.com. [url=http://us.rd.yahoo.com/evt=42974/*http://www.yahoo.com/preview] Check it out.[/url] [quote][b]
