flysrv10(at)gmail.com Guest
Posted: Fri Aug 11, 2006 4:53 am Post subject: Tunnel Heat |
I insulated the tunnel, including the fuel lines (fear of vapor lock)
and found that it made absolutely NO DIFFERENCE in the radiating heat
from the tunnel. I will next try the Y hose split as suggested by
Van and really hope that I can get results.
RV10 Tunnel - 2
111.08 KB |
281 Time(s) |
