Sean Blair
Joined: 09 Jan 2006 Posts: 39 Location: Colorado Springs
Posted: Wed Aug 09, 2006 8:44 pm Post subject: lighting |
Okay…..another one. I plan to install LED position lighting. Any recommendations? I’ll be using a 12 volt system.
Is there a 12 volt LED strobe available? I see Whelen has one, but it’s a 24 volt.
Thanks again,
Sean Blair
#40225
_________________ Sean S. Blair
#40225
N967SB (reserved) |
EFDsteve(at)AOL.COM Guest
Posted: Wed Aug 09, 2006 9:13 pm Post subject: lighting |
Check out Jeff Bordelon's site: http://www.jeffsrv-7a.com/LEDPROJECT.htm
I think that these are very nice. I'm using these wingtip0 position lights, tho I'm not sure what I'm using for the tail yet.
Steve Weinstock
40230
Okay…..another one. I plan0 to install LED position lighting. Any recommendations? I’ll be0 using a 12 volt system.
Is there a 12 volt LED strobe0 available? I see Whelen has one, but it’s a 240 volt.
Thanks0 again,
Sean0 Blair
#402250
[/quote]
Posted: Thu Aug 10, 2006 12:57 pm Post subject: lighting |
There are many LED nav light kits. Currently no tail light LED/Strobe combos, so I went with the standard Whelen that Van’s recommends. Hopefully someone will make an LED retrofit for the same Whelen housing when the technology permits.
Rob Wright
#392
Wings (L HID)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of EFDsteve(at)AOL.COM
Sent: Thursday, August 10, 2006 12:13 AM
Subject: Re: lighting
I think that these are very nice. I'm using these wingtip position lights, tho I'm not sure what I'm using for the tail yet.
Steve Weinstock
40230
Thanks again,
Sean Blair
#40225 |
mike(at)learningplanet.co Guest
Posted: Thu Aug 10, 2006 1:25 pm Post subject: lighting |
I installed the CreativAir Wingtip LED position, strobe, and landing light setup in my -9A and have been very happy with it so far. The construction process was fun and relatively painless. I used the Whelen tail position/strobe in the back of the rudder.
http://www.my9a.com/lights.asp
One thing that I noticed however about this system is that since the lights are designed for the smaller wingtips on the 7/8/9, asthetically it seems a bit too small in the wingtip of the -10. Maybe they'll come up with a slightly larger layout for the -10 before I need to make a decision because otherwise I really like the product.
Mike Schipper
RV-10 - #40576 - Emp. - www.rvten.com
RV-9A - N63MS - Flying - www.my9a.com
On Aug 10, 2006, at 3:56 PM, Robert G. Wright wrote:
Thanks again,
Sean Blair
#40225 |
LarryRosen
Posted: Fri Aug 11, 2006 6:58 am Post subject: lighting |
Perihelion design has a white led retrofit for the Whelen A555 tail lamp
it is for the position lamp only and not the strobe. See it here
<http://www.periheliondesign.com/ledlights.htm>. It is pricey at $139
and you still need the Whelen A555.
Larry Rosen
#356
Sean Blair wrote:
it’s a 24 volt.
Thanks again,
Sean Blair
#40225
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
