Skidded turn traffic pattern stall video
rparigor(at)suffolk.lib.n
PostPosted: Wed Aug 09, 2006 6:19 pm    Post subject: Skidded turn traffic pattern stall video Reply with quote
Saw this on a RV Newsgroup.
Ron Parigoris
http://www.apstraining.com/clips/skidded_turn_high.wmv
The real problem is stalling while in an uncoordinated turn. In a normal
stall, your wing stalls near the root first - that turbulent air hits the
tail and gives you whatever buffet you're going to get, depending on the
plane.
In a skidded turn, the stall happens further out on the wing and there's
no warning at all - the turbulent air 'misses' the tail. Worse, the first
part of the wing to stall is right out there near the inside wing's
aileron, so you basically lose that too.
The point is that even in a plane that usually gives lots of warning
before stalling, you likely won't get the same warning in an
uncoordinated, turning 'traffic-pattern-type' stall.
See very cool video here.
96victor(at)gmail.com
PostPosted: Wed Aug 09, 2006 6:45 pm    Post subject: Skidded turn traffic pattern stall video Reply with quote
Thanks Ron
The video of the skidded turn is great! I was first taught 50 years ago to always coordinate turns. No reason was given that an emphasis was placed on landing pattern turns sans the reason why. I have always tried to coordinate turns at all times and was not aware of the problem at low speeds.
I am not quite flying but I would like to hear the experience of you fly guys or girls if you practice it in landing configuration at altitude. I will practice it when I fly, not just for my own learning but for others that I can preach to..
Tom XS/mono/Jab/airmaster/RiteAngleAoA/N96victor/EllensburgWA
On 8/9/06, rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us) <rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us)> wrote:
--> Europa-List message posted by: <rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us)>
Ron Parigoris
plane.
PostPosted: Wed Aug 09, 2006 8:27 pm    Post subject: Skidded turn traffic pattern stall video Reply with quote
Hello Tom
"The video of the skidded turn is great!"
Try these too:
http://www.apstraining.com/newsletterlist.htm
I guess this forum should be renamed Training 101.
Ron Parigoris
william(at)wrmills.plus.c
PostPosted: Wed Aug 09, 2006 9:13 pm    Post subject: Skidded turn traffic pattern stall video Reply with quote
Ron and All,
I can appreciate what happens in an uncoordinated turns when the A/C is
"skidding", i.e. bottom rudder, but I have always been led to believe (and
from my personal experience), that a "slipping" turn, i.e. top rudder, is a
safe manoeuvre and a good way to lose height rapidly. Also a straight side
slip, perhaps on finals to lose more height than flaps alone will generate,
i.e. crossed controls, is safe provided the nose is raised after the
controls are crossed and lowered before the controls are centred. I was
instructed and have instructed these manoeuvres (in gliding) without any
problem and I have the belief that it is impossible to enter a spin from
crossed controls, because the inside wing is leading. Has anyone else been
instructed or has instructed this as well, power or gliding?
Best wishes,
William
gcrowder2
PostPosted: Wed Aug 09, 2006 10:29 pm    Post subject: Skidded turn traffic pattern stall video Reply with quote
I just asked my instructor of 30 yrs last week about this and he said that
the stall/spin
entry occurs on the base to final turn because a lot of pilots are afraid
of using too much
bank angle When they get to the bank angle they're comfortable with and
still need some more to make the turn, they will use bottom rudder to
tighten the
turn without banking more, causing the stall just like on the video.
My instructor also said it is safe to use top rudder causing a slipping
turn because even
if a stall occurs, the high outside wing will stall first, then only causing
the stalled wing
to return to level. This can be then caught in time to stop a spin entry to
the outside.
I can see there could be a variety of opinions here but it seems there
would be more time to
correct and fly out of the stall.
Glenn
[quote]From: "William Mills" <william(at)wrmills.plus.com>
Reply-To: europa-list(at)matronics.com
To: <europa-list(at)matronics.com>
Subject: Re: Skidded turn traffic pattern stall video
Date: Thu, 10 Aug 2006 06:11:46 +0100
Ron and All,
Best wishes,
William
grahamsingleton(at)btinte
PostPosted: Thu Aug 10, 2006 1:11 am    Post subject: Skidded turn traffic pattern stall video Reply with quote
William
It certainly isn't impossible to spin from a sideslip. The "outside"
wing is shielded by the fuselage so if speed gets too low the aircraft
will flick towards the outside wing. Did it in a Condor once.
Graham
William Mills wrote:
I was instructed and have instructed these manoeuvres (in gliding)
without any problem and I have the belief that it is impossible to
enter a spin from crossed controls, because the inside wing is
leading. Has anyone else been instructed or has instructed this as
Best wishes,
William
wdaniell(at)etb.net.co
PostPosted: Thu Aug 10, 2006 3:48 am    Post subject: Skidded turn traffic pattern stall video Reply with quote
I thought that in sideslip provided you had nose well below the horizon you
were safe - obviously not. What happened?
davidjoyce(at)doctors.org
PostPosted: Thu Aug 10, 2006 4:14 am    Post subject: Skidded turn traffic pattern stall video Reply with quote
William, For a gliding tug pilot landing over trees and slideslipping down
to round out level was pretty much routine, and I have naturally
slideslipped my Europa when appropriate (such as PFLs) I have to say that it
has always behaved impeccably and felt entirely comfortable in the
slideslip. There is a natural tendency for speed to build up in the slip
unless you go out of your way to prevent it and I think it is very unlikely
that someone would inadvertently stall in the process. Regards, David Joyce,
G-XSDJ
jthursby(at)tampabay.rr.c
PostPosted: Thu Aug 10, 2006 4:47 am    Post subject: Skidded turn traffic pattern stall video Reply with quote
You are. It's when the nose comes up that you better watch out. The plane
will do some interesing things then. Make sure you have some spin training
and go try it out up above six or eight thousand feet. When I flew the
company planes I had wondered about this so on the urging of Clive Davidson
I took the mono out one day, climbed up high and proceded to manhandle it
around mock landing approaches to see it's (and my) limits. Full rudder
slips are a joy to see but if the windscreen isn't half or more full of
green you had better push it over. I found if you had the approach trimmed
hands off you were pushing a couple pounds of down elevator to maintain a
good/safe slip. I also found that if you did try something stupid with the
bank angle or rudder goosing it to half throttle would hold off the stall to
a much higher angle and increase your margins. (remember your power on
stalls?)
James T.
PostPosted: Thu Aug 10, 2006 5:31 am    Post subject: Skidded turn traffic pattern stall video Reply with quote
William
You probably would be safe if the nose was kept low, but to maximise the
sink rate in a sideslip or slipping turn, the nose needs to be raised above
the horizon.
In a glider I suspect the wings are long enough and the fuselage slim enough
for the shielding effect (that Graham mentions) not to cause the trailing
wing to stall. I have intentionally abused gliders in both slipping turns
and sideslips (at a safe height) without experiencing any undesirable
results. However, in the case of the Europa with short wings and a
relatively large fuselage, I can appreciate Graham's point that it might tip
towards the trailing wing if the manoeuvre is taken to the extremes.
Although I have comfortably sideslipped my Europa on many occasions, when
too high on the approach, without any problems, I will have to do some
experimenting at a safe height, of course, to see what happens if I take it
to the extremes!
Hope that helps,
William
PostPosted: Thu Aug 10, 2006 7:28 am    Post subject: Skidded turn traffic pattern stall video Reply with quote
Nose wasn't well below the horizon, I was exploring the envelope. Plenty
of height for recovery. This was in the days when I was gliding (and
towing gliders) We used to have a lot of confidence in our ability to
recover from a spin. Sometimes that confidence was unwise because
airplanes that are hard to spin are also hard to recover. No one told us
that!
Graham
ami(at)mcfadyean.freeserv
PostPosted: Thu Aug 10, 2006 2:56 pm    Post subject: Skidded turn traffic pattern stall video Reply with quote
Perhaps I'm missing something, but I don't find sideslipping a Europa to be
a beneficial means of losing height on the approach. That is (in addition to
the fact that sink rate isn't increased by much), given the lack of
confidence in the ASI reading during a side slip, I always make sure to
speed up a bit. That means extra speed when coming out of the side slip and
(if it's a short strip) a missed approach as a consequence. Or if the height
control is needed further out on the approach, S-turns will do the job.
Co-ordinated of course!
Duncan McF.
PostPosted: Thu Aug 10, 2006 3:37 pm    Post subject: Skidded turn traffic pattern stall video Reply with quote
thanks
PostPosted: Fri Aug 11, 2006 12:38 am    Post subject: Skidded turn traffic pattern stall video Reply with quote
Duncan, I find that on approach idling I have 550 fpm down (from memory) and
this increases to 700-750 down with full L. rudder side slip. Not dramatic
but if you have got a forced landing approach almost right it is a perfect
way of fine tuning. If you are way too high then S turns are the thing, but
they bring their own risks of course. Regards, David
