Rick S.
Posted: Wed Aug 09, 2006 4:10 pm Post subject: Arc protection diodes |
Anyone else who built their own trim/relay board know the value for the diode rectifiers used to protect the relay and trim switches from arcing the contacts? Or any on who used the Aircraft Extras or Ray Allen relay decks know what value they put in their decks?
I suspect a 1 amp by 50 volt should do. Circut draws less than an amp.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
carl.froehlich(at)cox.net Guest
Posted: Wed Aug 09, 2006 4:45 pm Post subject: Arc protection diodes |
I built up my own0 trim/flap relay board for my 8A, no diodes. The current draw is too0 small.
Carl0 Froehlich
RV-8A (2600 hrs)
RV-10 (tail0 cone)
[quote] --
Ray.R.Doerr(at)sprint.com Guest
Posted: Thu Aug 10, 2006 7:27 am Post subject: Arc protection diodes |
I built my own Trim/Flap controller board for my RV-9 and RV-10. It uses all solid state MosFet so there is no moving parts to wear out. I used 50 Amp Mosfet for the Flap motor so they don’t even get the least bit hot.
Thank You
Ray Doerr
CDNI Principal Engineer
Sprint PCS
16020 West 113th Street
Lenexa, KS 66219
Mailstop KSLNXK0101
(913) 859-1414 (Office)
(913) 226-0106 (Pcs)
(913) 859-1234 (Fax)
