Fuel Label / Placards
Tim(at)MyRV10.com
PostPosted: Thu Jan 19, 2006 6:29 am    Post subject: Fuel Label / Placards Reply with quote
Darn, I forgot to order my data plate and nameplate, along with
fuel quantity and type stickers.
I've got 2 questions:
If someone is home today near their wings, can I get a measurement
on the size of the hole around the fuel caps? I'm going to go
get some vinyl cut letters that say "100 LL - 60 US Gal" cut in
an arc around the fuel opening. I'd like to make the arc of the
letters only about 1/4 to 1/2" larger than the arc of the opening.
As for the dataplate, I know the regs require only this:
Per FAR 45.13 "Identification data" all that is required on the
(fireproof) data plate is (1) Builder's name, (2) Model designation, and
(3) Builder's serial number.
What about the nameplate?
I'm talking about this one at ACS p/n 09-33200
http://www.aircraftspruce.com/pdf/catalog/Cat06348.pdf
They have fields for:
Model:
Serial No.:
Empty Wt.:
Date of Mfg.:
Gross Wt.:
Engine:
H.P.:
Built by
Name:
Address:
City/State:
How much of that is required info? I don't have an empty wt. yet,
but if it wasn't required, I would just skip it.
Almost done in the cockpit, so it's some finishing touches
on the engine, wiring, doors, and then maybe wheel pants and
then it's going to the airport.
Tim
Tim Olson -- RV-10 #40170
DO NOT ARCHIVE
Deems Davis
PostPosted: Thu Jan 19, 2006 7:23 am    Post subject: Fuel Label / Placards Reply with quote
Tim, just went out and measured, the diameter of the fuel cap opening in
wing is 2 5/16" diameter.
Deems Davis # 406
Wings
http://deemsrv10.com/
and (3) Builder's serial number.
Model:
Serial No.:
Empty Wt.:
Date of Mfg.:
Gross Wt.:
Engine:
H.P.:
Built by
Name:
Address:
City/State:
Tim
LarryRosen
PostPosted: Thu Jan 19, 2006 8:10 am    Post subject: Fuel Label / Placards Reply with quote
Tim,
I believe you want the volume of each tank identified by the fuel
opening "30 U.S. Gal. 100 LL" not the volume of both tanks.
Another option in lieu of vinyl cut letters is to have the fuel cap
engraved. Dan C did it that way. He used Bill Esther. Here is the
link to the fuel caps on Dan's site
<http://www.rvproject.com/esther_engraving.html>
Another engraving source is here
<http://www.engravers.net/main/ac_products.htm> they have both fuel caps
and data plates and other engraved products.
Vans has a "Vans Air force" data plate. But you probably already know that.
Larry Rosen
<http://lrosen.nerv10.com>
Tim Olson wrote:
... I'm going to go
Tim
Larry Rosen
#40356
N205EN (reserved)
<http>
Tdawson(at)avidyne.com
PostPosted: Thu Jan 19, 2006 8:29 am    Post subject: Fuel Label / Placards Reply with quote
There's no requirement for labeling the fuel cap, is there? My
understanding was there was just the requirement for labeling the fuel
selector inside. I guess I could go look that up . . .
TDT
Tim(at)MyRV10.com
PostPosted: Thu Jan 19, 2006 8:40 am    Post subject: Fuel Label / Placards Reply with quote
Good point. I actually drew it up that way but when I wrote the
email I messed up my thinking again. Yes...30 per side.
I think the engraving would be perfect...I just want to get
the vinyl for now because it's temporary and quick. I
don't want to send out the fuel caps and have a delay on flying.
Plus, my caps are currently painted and would need stripping.
Yep, I did know about the VAF data plate. I actually think
I'll maybe get the aircraft spruce version instead,
p/n 09-40000 AIRCRAFT ID PLATE EXPERIMENTAL from Aircraft
Spruce. It's 1x3" and doesn't have places for the fields
that I wouldn't want to fill. My main concern right now is
finding which place I can order from who includes engraving
and can ship it out relatively quickly.
The name plate though, I think is a separate requirement, inside
the cockpit, right? So that's the one that I'm worried
most about today. Can't figure out what that one all requires.
DO NOT ARCHIVE
Larry Rosen wrote:
Tim,
that.
Larry Rosen
Tim Olson wrote:
> ... I'm going to go
> Tim
Tim(at)MyRV10.com
PostPosted: Thu Jan 19, 2006 8:53 am    Post subject: Fuel Label / Placards Reply with quote
I'm not 100% sure it's a requirment or not, but I believe that it's
one of the things the inspectors look for. A label near the fuel
filler opening (or on the cap) that says the quantity and type
of fuel. Makes sense, since fuel related problems are one of the
largest causes of accidents. I know in my Beech, the POH actually
had pages with all of the required placards on it, and they
had a nice one that went by the filler necks.
I attached what I plan to use. Randy or one of the other people
flying may be able to tell you what they found/heard.
Tim
TDT
 Filesize:  17.34 KB
 Viewed:  1043 Time(s)
wayne(at)engravers.net
PostPosted: Thu Jan 19, 2006 9:43 am    Post subject: Fuel Label / Placards Reply with quote
Tim,
Try http://engravers.net/aircraft/fuel_caps.htm to see if you would prefer
to have the fuel caps engraved directly.
Wayne Cahoon
Aircraft Engravers
(860) 653-2780
(860) 653-7324 Fax
NYTerminat(at)aol.com
PostPosted: Thu Jan 19, 2006 3:05 pm    Post subject: Fuel Label / Placards Reply with quote
I just had a DAR inspection on my Zenith, he wanted fuel quantity and type at the filler opening of each tank and also a fuel quantity label at my gauges. For those not using gauges and using the engine monitor there must be a way of showing the quantity. I. D. Data plate does not require empty weight.
Bob Spudis
In a message dated 1/19/2006 11:55:16 AM Eastern Standard Time, Tim(at)MyRV10.com writes:
Tim
armywrights(at)adelphia.n
PostPosted: Thu Jan 19, 2006 3:53 pm    Post subject: Fuel Label / Placards Reply with quote
Well, let's see. It's an experimental airplane:
Empty Wt can change depending on installed components
Gross Wt can change if you include mods that allow (tip tanks, etc) for it.
Engine/H.P. _could_ change in the future
Address/City/State: You _could_ move or base somewhere else.
Granted, some of the above might precipitate a new Phase I for flight
characteristic changes, but as an OBAM, you know you're not bound to a TC.
I'd only include the required plus any item that you _know_ won't change.
Date of Manuf. could be a good one.
Rob
Ray.R.Doerr(at)sprint.com
PostPosted: Fri Jan 20, 2006 6:42 am    Post subject: Fuel Label / Placards Reply with quote
You could do something like this instead. I did this on my
RV-9A and also had the N number on it in the middle.
Thank You
Ray Doerr
40250
 Filesize:  28.03 KB
 Viewed:  998 Time(s)
